Grassstrip,
You beat me to the punch last night as I was reading the same texts for Student. I have Cessna manuals for the 1980 c150, 172N, 172R, 172S, 182S,
and it's all the same. Chapter 4 is the chapter for normal procedures in all Cessna books. A quick look shows this procedure to be the case for all short field (not standard) landings.
This is what "Jimmys big brother, the
FAA rekons", maybe we should "trust him, since he knows better":lol:
FAA-H-8083-3 the FAA / USDOT book "Airplane Fling Handbook" Ch14 pg15 under Short field landing:
Short field landing procedures are similar to in a normal approach and landing. Approach with full flaps at the recommended short field approach speed. If a recommended speed is not furnished, after landing is assured and the wing flaps are extended, a rule of thumb is 1.2 Vso, but not less than Vmc for safety.
Immediately after touchdown, raise the flaps, apply the back-elevator pressure and apply brakes.
A source more widely accepted by back country type (F.E. Potts) says this:
Ch19, Pg 138, Pp "
Use of flaps - high wind conditions "
....Then coming over the threshold with
full flaps, he reaches down and
releases the flap lever so that flaps go to 0*. This is done just at flare, and when the timing is right the airplane drops on to the ground nicely in the three point attitude, then if the strip is smooth, hard, and long enough, the pilot brings his airplane up to the three point position and applies his brakes.
later in the same chapter, under the paragraph "tricycle gear (c206)"
.... 3)
Needless to say, flaps should be retracted right at touchdown.
and the chapter ends with this:
( It should be noted that a lot of instructors take a very strict position on retracting the flaps during the landing roll: you are not to do it under any circumstances. The reason for this is that a lot of pilots have managed to retract the gear accidentally while thinking they are retracting the flaps. And I will admit for those of you that will be going from 152s to light twins, to commuters, to the airlines, this may be a reasonable position to take. For those pilots will rarely have an opportunity to operate from seriously marginal strips.
However bush flying is a very different game and it uses mostly fixed gear airplanes, so this quite sensible rule has to be disregarded if you are to operate under those conditions.)
Looking at Sparky Imeson' " Mountain Flying Bible"
There are so many references to this maneuver, that I would basically be re-writing the book to illustrate them all. Apparently, my "big brother" Sparky approves
. I will point out this however, Sparky is the only one who uses your words of "Dumping the flaps" verbatim. And he does so as he describes a botched approach arriving at the threshold floating. Whereby he suggests a forward slip,
Dumping the flaps or a combination of both. See page 5-47 Ch "
SHORT-FIELD PRECAUTIONS
I have been at this situation a few times.... It can be a handful (for me) but when the choice is get down and on the brakes, or use the trees at the end for brakes, it is a no-brainer...
Student Pilot,
I really have to thank you for bringing up this thread. I currently have good blocks of "spare time" I study a lot during these times, but this thread gave me the opportunity to go back and revisit a few good books like "stick and rudder", Sparkys, and Potts'
Take care, Rob
