Only the 172 for now but the STC covers Primary flight instruments as well as primary engine instruments, ADSB, Autopilot...the works.
And is IFR approved as well.
I'm so glad I havent bought anything for the panel just yet. This might cause me to re-think everything.
Going to check into getting a field approval in a 170 using the 172's STC as basis.
http://www.dynonavionics.com/certified/
DYNON CERTIFIED UPDATE
SkyView HDX is now STC Approved!
We're excited to share that we've just received our first Supplemental Type Certificate (STC) for our flagship SkyView HDX system. The STC’s Approved Model List (AML), which initially covers many Cessna 172 models, ushers in a new era of truly affordable, safety-enhancing integrated avionics systems for type certificated aircraft.
The initial STC is for the installation of a full suite of Dynon avionics, allowing pilots to remove the vast majority of their legacy instrumentation, including their vacuum pump. The SkyView HDX system provides complete primary flight instrumentation, including synthetic vision and angle of attack, and complete engine monitoring with CHTs, EGTs, fuel flow, fuel computer, and lean assist. Also approved is Dynon’s fully-integrated two axis autopilot, which features IFR approach capability when SkyView is integrated with a compatible navigator. The approved installation also includes a Mode S Transponder with 2020-compliant ADS-B Out, Navigation and Mapping with Flight Planning ADS-B Traffic and Weather display, and Electronic Flight Bag features. Backup primary flight instruments are provided by a Dynon EFIS-D10A.
Approved Model List
The initial Approved Model List (AML) covers Cessna 172F, 172G, 172H, 172I, 172K, 172L, 172M, 172N, 172P, 172Q, 172R, and 172S models. Approval does not restrict the operational use of the aircraft, and allows for flight in both IFR and VFR. Dynon will be seeking additional approvals for both single and twin-engine aircraft in the coming months.
