heli_adams wrote:So after much deliberating and discussion, I've decided to purchase a C180. I know I want an early one, because they are the lightest and happen to be the most affordable. I know the A and the J O-470's are the least desirable, however I've read zero major complaints about them and they are the two engines in the two of the three aircraft that I'm currently looking at. I will be flying around Idaho into short and soft fields with high da's. My max budget is 70k. Here's the rundown and thus my dilemma.
A/C 1: 1953 w/ O-470-A. 2500 TT Horton Stol/185 Gear legs. Fresh Overhaul. No significant damage history.
A/C 2: 1953 w/ O-470-J. 6000 TT 1100 SMOH. Wing and nose damaged. Repaired and wing replaced. 31" bushwheels.
A/C 3: 1955 w/ O-470-R 18000 TT. Fresh overhaul. Lived on Saltwater most its life, sank it salt water at one point. Apparently no corrosion :/
As you can see there seem to be pros and cons for each of these aircraft. In your opinion, which would be the most worthwhile to have a look at, or should I wait for one to come along that checks the more desirable boxes?
I would
run away from an aluminum airplane that has been submerged in saltwater.
It's wise to avoid letting goodies like bushwheels, STOL kits, avionics, shiny paint or pretty upholstery from significantly influencing your decision. These things can be distractions from features that are more important and these improvements can be made over time if you really want them.
Damage history can be a curse or a blessing. A pair of wings, tail surfaces or fuselages that were properly rebuilt ten years ago can certainly be better than beat up old parts that have been worked, dented, filled with bondo, stop drilled, patched or neglected for 65 years, while maintaining spotless airframe log books. My plane flies like an absolute dream with three major repairs in the books.
Also, elimination of damage history documentation in logs is not all that uncommon. Most of these old girls have been around a time or two. One that claims "I have never" should raise an eyebrow.
I've heard that Continental will not support an A-model 470. Not sure if it's true, but they definitely have a markedly compromised reputation.
The details of any "fresh overhaul" should also be considered.
There are few perfect examples, which is evident in the sample that you present. My advice is to find a mechanic who knows skywagons to do a thorough prebuy inspection. If any of these planes are real nice, and inexpensive, go for it. If not, be patient, you will end up finding a good example for a decent price.
I personally, like the 55 and 56 models the best out of the early planes, but I prefer the mid to late 60s models because of the higher gross weight and beefier airframes.
