DENNY wrote:In general three things help a plane fly Wing, Prop, and Power. If you want to land short a big extended wing with drooped ailerons and front cuff will let you fly slower, land and stop a lot shorter. It will also lift the same weight off sooner (given proper AOA). The right prop will give you a lot of grunt getting into the air and more HP will let you climb hard.
USEFUL LOAD;
What does it mean to you? My 1951 piper pa18A can carry 2,070 in utility category with a 125hp motor. Take the hopper out and booms off now we can fly standard category at 1500 lbs. If you look some of the V speeds change but all are within a 82/43 borer with a 160 hp lower performance range. In the country of ALASKA the FAA says 121 or part 135 operators can fly certain planes at 115% of max weight. On a -30 degree January day my it is hard to for women not to want to have the baby of a cub driver. Go to Fairbanks on a 100 degree july day and you might need to bring some good booze and a promise for a trip to Vegas, for a woman to say hi.
LEGAL LOAD;
What the paperwork says.
If you are landing on smooth stuff a properly set up 182 will have a better AOA than a 180, performance will follow AOA.
No right or wrong just things to think about.
DENNY
Sorry, Denny, but there are a bunch of mis-statements there. For one, try to argue during a ramp check that 115% gross is legal, in 121 or 135.
And a 182 has better AOA than a 180? I think you’re mixing your metaphors, lad.
