Greetings lads and laddies:
N28751 has been put back together after the SB96-11B inspection. We put in a standard crank (no 10 under grind) and all standard bearings. New rod bearings, main crankshaft bearings and a new prop end bearing. (them suckers ain't cheep dudes, the big bearing on the end.) Crank is fresh yellow tagged with a fresh magneflux inspection. It's got about 185 SMOH and 1 hour on the new stuff. I'd say it's fresh really. I'm stoked. It came to $13,670.54 for the airplane and my negotiated share of the prop strike fix. I got a fair size bill building for the pre-buy inspection and dual needed too. Still, not bad you know?
Now all I got to do is learn how it works and fly off the insurance hours and bring it home. I'm excited. I'll be to the Austin fly in for sure, Copperstate is calling too.
I really need to figger out this climb prop deal though. I don't have a clue. Most of the guys on the Luscombe lists are flatlanders. I also have no idea what's on there now either but if it goes like hell it would be a shame to repitch a new prop. I dunno. Does a guy need a climb prop all year? Being it's an 8C means I'm limited to 72". A-75.
Today it was over 8000' out there at 1:30PM. And then it got hot. Fly early and fly often me-thinks. I don't know when I'll be bringing it South for sure. It's hard to say but I think Lebanon has good car gas so if the weather works I'll come down on the inside and cross over at about Quincy to Susanville kinda. Follow roads. Six hours with a pee/fuel stop. Sure wish I had a camera to hang on the wing.
About ten years groundbound.
EB
