Backcountry Pilot • Engine Vibration
Engine Vibration
6 postsPage 1 of 1
Engine Vibration
Hey guys, I’m new to the forum but am excited to learn as much as I can here. I fly a citabria 7gcbc and all is well except some engine vibration (especially between 2100-2300 rpm) I’ve heard quite a bit about prop indexing making a big difference and was hoping to get some feedback from anyone who has experience with it. By the way it’s an 0-320 150hp. Thanks!
Apex1145 offline
Aircraft: Citabria 7gcbc
Re: Engine Vibration
Welcome to the group!
I can't help with this question, but welcome :)
Sneaky engine vibes have been the hobbyist diagnostician's bane since the dawn of the combustion engine. I'm no expert, other than being able to type:
Definitely find a shop with a Chadwick or comparable prop balancer device, and make sure they know how to use it by using the word "ips" gratuitously and seeing how they respond. If they know lower is better, then they're competent. :D You should get a dynamic prop balance either way. They can make what you thought was a smooth engine even better.
I suspect your problem though is different if it's in that narrow RPM range. It could easily be ignition or fuel delivery. Those two things suffer the most variables and potential for wackiness.
I had a magneto once that had a tick/vibe to it that was only noticeable at full power. R&R and it was good as new.
Spark plugs are life limited and will often fail slowly and with some vibration at certain RPM. I had a plug go bad once, not just fouled, but something fundamental like a cracked insulator or something... it felt like the engine was throwing a rod, but only in a narrow RPM range.
Sometimes the magic that routes the atomized fuel into cylinders can cause an imbalance. Carbs need a little TLC now and then. The Cessna 170 used to have a venturi AD if I remember correctly. But I don't remember the exact details.
Just have to start trying stuff and use process of elimination.
Thanks! It may just be in my head. I did some pattern work this evening and it seemed fine. I fly several hours at a time and could be that I’m over analyzing things. I’ll keep an eye on things and follow up on anything I find.
Apex1145 offline
Where you over "unlandable" terrain at the time :wink:
Let me ask the obvious question. Is this a recent thing, or has this engine always had the vibration? I am always up to playing the "Car Guys" of aviation challenge.
dogpilot offline
Took ball and went home
6 postsPage 1 of 1
