My seat belts have this style of ends:
I planned to used this style of l-track stud:
Some type of carabiner or shackle would work but I can't determine if any are FAA approved which they need to be for the DAR to accept the installation.
Any ideas?
whee wrote: if any are FAA approved which they need to be for the DAR to accept the installation.
Zzz wrote:whee wrote: if any are FAA approved which they need to be for the DAR to accept the installation.
Is this something relegated to restraint systems? Do DARs often require FAA approval of every fastener or connection?
hotrod180 wrote:Are your ends sewn onto the belts or threaded on?
My pax belts have clip-on fittings.
Google aircraft spruce clip on seat belt fittings.
c180bill wrote:The "double-lug stud fitting" locks to the track with a lock nut. ( 3/8-24 ) 1833 lb working load.
You would need to fabricate a metal extension to allow the belt "end fitting" to swivel, lay flat, or orient properly.
dogpilot wrote:Seat belt attach points do have special regulations. If memory serves me correctly, the restrains must be able to restrain a standard FAA defined human at 10g acceleration. The reason for this, is above 10g, you essentially come apart internally in a rapid deceleration. So a restraint should be able to hold 180 lbs x 10g or 1,800. The seat track fittings on Ford type track, single point are 150 lb and double foot attachments are 250 lb. So these would be very inadequate for use as a restraint. That being said, skydivers frequently use two double point attachments to secure skydivers (meatbombs) seatbelts to the floor for jumping. They have STC's for that attachment system that go along with the benches used. They have very loose standards for nearly everything skydivery
PA1195 wrote:1. Some 5/32 or larger cable, two thimbles, and two nicopress fittings per belt end between belt and ring.
2. Two flat ski cable to landing gear bolt tabs with AN hardware through the two punched holes. One bolt though belt end hole the other through the ring clamping the tabs over both. Atlee Dodge product.
3. https://www.aircraftspruce.com/catalog/ ... /an115.php or https://www.univair.com/categories/hard ... ckles.html
dogpilot wrote:Seat belt attach points do have special regulations. If memory serves me correctly, the restrains must be able to restrain a standard FAA defined human at 10g acceleration. The reason for this, is above 10g, you essentially come apart internally in a rapid deceleration. So a restraint should be able to hold 180 lbs x 10g or 1,800. The seat track fittings on Ford type track, single point are 150 lb and double foot attachments are 250 lb. So these would be very inadequate for use as a restraint. ...
Bagarre wrote:Yours is Experimental, why do you need a DAR’s approval?
