Backcountry Pilot • Ferry flight: W Colorado to Maine--RANS S-20
14 postsPage 1 of 1
Last week (April 2025) I ferried a RANS S-20 Raven from Western Colorado to central Maine. The plan was the new owner would join me near Des Moines.
Trip Summary
* 2,100+ statute miles, 17.7 hours
* Generally 30 to 40+ mph tailwinds at altitude for two days
* Average fuel burn ~ 6 gph
Fuel & Overnight Stops:
• Delta, CO, KAJZ
• Ogallala, NE, KOGA
• Ankeny, Iowa, KIKV
• Bult Field, Monee IL, C56—overnight
• Wayne County, Wooster OH, KBJJ
• Fulton County, New York. NY0
• Norridgewock, Maine, KOWK—home base
Key considerations:
• Looked for potential 2-day weather window; Did not want to get stuck in the middle-of-nowhere for day(s) due to weather or winds
Two day weather window all the way across the country almost impossible! I was dreaming!
• Ideal if upper winds were favorable with 2-day tailwinds
• Fuel capacity: 26 gallons; Expected fuel burn ~ 6 gph
Looking for 2.5 to 3.0 hour legs, leaving very conservative 1+ hour reserves
• Predicted surface winds were KEY. This is a light-sport with a maximum 12-knot crosswind capability—and I didn’t want to push the limits!
• Surface wind predictions, along with 2.5-3 hour desired legs, had me looking for airports whose runways ideally aligned with the forecast wind
Getting over the Continental Divide at any time of year can be challenging
o Wanted forecasted winds at 14,000’ to be less than 30 knots
o Looking ahead with https://windy.com in conjunction with the wind forecast tab within ForeFlight were key
o Also hugely useful are the actual wind reporting stations at:
 Colorado AWOS map (https://www.codot.gov/programs/COMtnAWOSMap)
 FAA weather cams (https://weathercams.faa.gov/map/-111.25917,36.1314,-104.59597,41.53136 zoomed in on Colorado)
 Actual weather reports on Colorado (snow) avalanche site (https://avalanche.state.co.us/weather/weather-stations), particularly Berthoud Pass & Monarch Pass; at the time of writing this article the winds at Monarch Pass are 39G48
Every morning I’d look at all the above websites. I particularly like the user interface and easy-to-scroll-ahead predictions at https://windy.com. BTW, I subscribe to Windy at the “Premium” level.
Here’s the planned route, with some minor deviations early crossing Colorado passes then later getting around Mode-C veil (Cleveland) and various Class-D airspace areas.
We also had a few MOA’s to pass thru. Most, thankfully, started at 8,000’ or higher. I did talk to Boston Center to verify Yankee 1 & 2, which started at 100’ in New York, were inactive.
A view of the panel:
Things worked out for a departure on April 21st. Normally I like to takeoff at dawn, especially when travelling over the Continental Divide.
Winds at the passes are, as you’d expect, often the lowest early in the am. Low winds at a Continental Divide pass means less than 30 knots.
However, on this trip, I was trying to balance winds-at-the-passes with predicted winds enroute at the first and subsequent stops. A strong front passed thru Western Colorado on Saturday—I was basically chasing behind that front two days later across the country. Hence predicted surface winds were quite high, but lowering as each day progressed. So I balanced a later-than-normal departure (7:30 am) with arriving mid morning at my first estimated stop (Ogallala Nebraska).
I crossed near Crested Butte (picture below) at about 13,500’ I stayed at that altitude until well past the Colorado mountains.
I saw plumes of snow ahead over the Collegiate Range. I expected turbulence, but only experienced a few light burbles.
I had a great view of Mt Princeton (14,200’) near Buena Vista, Colorado that I hiked up many years ago.
Again, though I expected turbulence over the Continental Divide, it was largely fairly smooth. However, as soon as I dropped down to about 9,500’ over Colorado’s Front Range, it got quite choppy. Here’s a picture passing Akron, Colorado.
Welcome to the flat-as-a-pancake Midwest!
It has been many years, perhaps 15+, since I’ve flown Eastern Colorado thru Nebraska. I can assure you, Nebraska has NOT gotten any prettier! What do I mean (sorry if you’re from Nebraska)…well here is a picture looking North near North Platte, Nebraska.
I was debating whether to stop in Ogallala Nebraska or North Platte for fuel. Imperial Nebraska would have been ideal, as their grass runway aligned almost perfectly with surface winds. But there is a NOTAM closing the grass runway until June 1st—I suspect to preserve the grass. Sigh. Ogallala it was.
Thence onward to Ankeny, Iowa, just N of Des Moines, to pick up the aircraft owner. Fuel stops were just long enough to fill up, use the restroom, stretch for 30 seconds and keep on trucking.
Out of the Des Moines area we still had a few hours of daylight left…if we could get in another stop we’d have some chance of perhaps getting to Maine the next day, of course weather and winds cooperating.
The next day we were passing thru Illinois. I was amazed at the size of the below BNSF railway car park at Elwood, Illinois. There must be a zillion cars and tractor-trailers there!!
Surface winds generally weren’t too bad, often 10G15+, but close enough to the available runway directions as to not present undue difficulty. At one stop, Fulton County NY (identifier NY0) the winds were 15G25 about 30° crosswind; We did a go-around on our first approach. The actual landing on grass adjacent to the runway was a non-event.
However, one of us had to remain in the airplane with the brakes on while the other fueled up—the surface wind was actually pushing the plane backwards even with wheel chocks in place!
Upper winds cooperated nicely! At altitudes between 5,500’ and later 9,500’ we generally had 30+ to sometimes 45+ mph tailwinds. Look at our groundspeed in the below image:
Speaking of MOA’s…we were at about 7,500’ with (I think it was DUKE MOA) starting at 8,000’ above us. Then I noticed traffic below us—as in almost at the surface! It was two C-130 aircraft at low-level in trail. I hope they had us on radar! It’s hard to see in the below picture, as they were painted all gray and blended in well with the terrain.
We passed by Elmira, New York—home of early soaring history (https://www.soaringmuseum.org/). I grew up near Elmira—it was special flying in this section of the cross-county journey.
As we got closer to central Maine I saw what seemed to me to be a series of gray fields up ahead. We made a slight deviation to discover they are solar panels.
It was getting towards evening on the 2nd day of the trip. We landed on runway 33 at KOWK, Norridewock, Maine at about 6:30 pm.
It was almost a perfect “greaser” landing. In what was an unanticipated end to an otherwise perfect trip—just as we had slowed to almost taxi speed, the left tire went flat! Geesh! All was good though with no problems other than having to tow the plane to the hangar.
Actual route:
Thank you for reading thru this!
tedwaltman offline
Re: Ferry flight: W Colorado to Maine--RANS S-20
Great report, thanks. I flew off of Harris Hill for a weekend many years ago in my LS4.
Wonderful report!!!!! And you weren't far from me when you went across Iowa. I still cherish the day over thirty yrs ago that I flew from Laughlin NV, Grand Junction, landing at Leadville, and up to 14,000 then downhill to Centennial airport on an almost calm day. My only Colorado flying.
Great report Ted, That's fairly close to the opposite track of when I came from Eastern Illinois to Idaho except I had the 30 to 45 mile per hour head winds.
Nebraska looks just about the same as it did then. Yuck!
shorton offline
Aircraft: Stinson 108-2
Very nice! Fulton Cty is about a hour southwest of me. Not sure what day you were there but it has been stupidly windy here the last couple of weeks. I do like that area of the southern green mountains into NH.
Pete
pburns offline
Aircraft: Champ 7AC
Thank you folks for reading and commenting. Much appreciated!
tedwaltman offline
These grips are triggering my trypophobia bigtime... What the heck are those? Corn cobs? A recycled didgeridoo? :lol:
Cholla cactus stems
tedwaltman offline
Nice trip report Ted! I've always looked at those Rans 20s and thought they'd be a nice airplane. Care to offer your thoughts on the type?
Thank you everyone again!
The RANS S-20 is a very capable light backcountry and cross country machine. Certainly very capable for most Idaho, Utah and Montana strips.
I did not build this one, but construction seems very straightforward and with ready access to everywhere on the fuselage, maintenance is a breeze. Access to the internal wing is minimal, but certainly enough for inspections.
This plane had a turbo Rotax 914UL, which made performance amazing. I climbed from 5,180 to 13,500’ pulling 36” of manifold pressure at an average of 65 mph at over 700 fpm. This plane had a whirlwind CS prop-a nice addition.
Controls are very light. Very responsive! A light touch is required.
Being a light sport, with a 700-something lb empty weight, finds one floating if airspeed isn’t managed well on final. I found about 52 mph w one notch of flaps to be quite comfortable on final.
Cruise at 9,500’ was about 110 mph indicated.
Getting in and out was relatively easy, even for the 6’ 5” buyer (who had plenty of extra headroom).
One small change I had made after purchase was to have the tail spring bent an additioal 1/2”, which totally eliminated all shimmy.
Overall an excellent, well designed aircraft!
Ted
tedwaltman offline
Thanks, Ted! As I'd guessed, seems like a very capable aircraft.
Great report Ted! I'm planning to fly from north of Seattle to Maryland this summer to spend a week at the beach with the grandkids. I'll budget enough time that I should be able to wander between back, or at least side -country strips out and back. On the way home I plane to spend a couple of days at AIrventure Oshkosh - again because it would be a shame to fly all that way and not include AIrVenture in the mix. I'll be in my Maule and it will be my 3rd and 4th flights all the way across the country and my 5th flight into KOSH during the show. I'm starting to get excited, but the increase in seriously bad weather over the past couple of years is giving me pause. I've already made the decision to park my Maule somewhere and fly the rest of the way commercially if thunderstorms with hail and tornadoes fill the summer skies across the Midwest. On my first flight from the West to the East Coast, a planned leg from Santa Fe, NM to Norman, OK required so many thunderstorm diversions that I wound up in North Platte, NB for the night. That detour is how I found out that the first airport in the US to install lights for night operations was in fact North Platte, KLBF. If I'm able to make this trip with enough stops on grass where I pitch my tent, I'll include a trip report and video here. If not, I guess you'll never know if it happened or not.
Thank you for the comments on your planned trip Flyhound. I’m hoping to be up in Alaska this July or I’d say “Stop in.”
Departures at dawn are key, at least in the West, to beating T-storms. Maybe not so much so in the Mid-West.
Enjoy your trip & be safe.
Ted
tedwaltman offline
Ted is spot on, early mornings for storm avoidance. This rule applies in the Midwest also. That being said, it doesn’t always work but even if there is not a threat of bad storms early mornings make for smoother and cooler rides. It’s well worth prying yourself and the people who are with you out of bed extra early to make a first light departure.
14 postsPage 1 of 1
