Thanks to ebag for sending me his drawings, I was able to make these seaplane bushings for my 180. Was a fun project on the lathe and they came out pretty nice I think.
I just finished making the 8 steel washers, machined, hardened, tempered and blued. The washers currently on the plane look like regular AN large area washers and are bending into the rubber bushings which are pretty much shot. I found dimensions for the washers on another post of the same topic here on BCP, and now I'm thinking they were dimensions for the SPW setup, and not necessarily the same size that came from the factory. I made them to 1" diameter and .100" thickness. I think the hardened washers are a bit overkill now that the rubber part of the sandwich will be gone, but want to keep it as stock as possible...unlike the current setup
Does anybody have the dimensions for the factory washers?? Or can you tell me if they look right in the pictures?
Also, after mocking up the setup on the bench, it's looking like the bolt may be one size too short, even though they are the longer bolts specified in the parts manual for the seaplane setup. Part of this may be because I can't accurately measure everything until I get it all apart, and part of it may be that the washers are too thick...remains to be seen, but I'm trying to figure this out before I take her down for the MX.
Another helpful dimension to have would be the thickness of the firewall/bracket sandwich that the bushings go through to make sure I'll have enough squeeze on the bushings before they bottom out. Measuring the bushings, I'll need slightly more than .285" to get them to torque down properly, but not too much that I'll run out of bolt length. I might be overthinking this part as I've seen more than one drawing for the bushing dimensions and they both matched. I can always machine off part of the chamfered edge on the bushings and get back 40-50 thousandths easily,
I've also ordered some new Lord mounts that are on the way, as soon as those arrive I'll start de-cowling and hopefully find out it all fits fine!!
For reference, in the pics the green protector is simulating the engine mount sleeve, and I have it all mocked up like it would be installed minus the nut. Also the washers in the foreground look bigger, but are all the same size (within a few thousandths anyways
