Right now they look like this. The cub is on Dollie’s but it’s still tight. The 170 wingtip touches cub underwing.
I’m thinking of adding a 10ft extension for cub tail. Any other cleverer ideas out there?
daedaluscan wrote:Yes everything is to scale. It’s the Hangar rash I’m trying to avoid, everything JUST fits now, but it’s inches from the walls. Never thought I would own two planes, should have built the hangar bigger.
NineThreeKilo wrote:Another vote for making a tail expansion
One of my old jobs had that problem, built a good sized hangar, plenty big for a turbine helicopter or GA single or two, but not big enough for any fixed wing turbo props, they had to blow the back of the hangar out and change the opening to get the helicopters fixed wing replacement in.
These days building a hangar, my theory is it needs to fit a king air 200 / PC12
Doubt I’ll ever get one, but it makes it plenty for a couple piston singles, and if I ever rent it out the amount of rent you can charge for one king air, Pilatus, citation is vastly more than two 172s
DreadPirateWill wrote:Naturally the answer is bigger hangar.
Out of the box thinking - what size tires on the cub? Maybe 35's would clear the 170 wing?
I have a set of these, work pretty well for lateral jockeying
https://www.harborfreight.com/automotive/jacks-jack-stands/vehicle-dollies/1300-lb-capacity-self-loading-positioning-wheel-dolly-64601.html
RC5280 wrote:How much ceiling space? Can you use a hoist or a lift?
https://hangartools.eu/products/hangar-lifts/#top
G44 wrote:https://www.summitracing.com/parts/ztc-6313pr?seid=srese1&ppckw=pmax-tools&gclid=EAIaIQobChMI1M_bn4CgjAMVG0n_AR38DiFVEAQYASABEgIEpPD_BwE
I have a set of these GoJack’s, they work great. Easy to use. We were able to get 2 Stearman and a Widgeon in a 50 by 50 hangar for winter storage using these, wasn’t easy but we did it.
Keep in mind, if the air leaks out of a tire there will be significant wing droop, this could cause significant damage to the wing depending on what is under it. It’s amazing how much a wing will droop even on smaller tires. As a rule I dont store things under the wings of my airplanes in the hangar.
