It's amazing the stuff you can learn on BCP. I had to look up "NOE:"
http://en.wikipedia.org/wiki/Nuclear_Overhauser_effect
My guess is that it's like ground effect, except if you're low enough, you get it at a nuclear level?
Rob wrote:
Norms comment on the GA safety record is somewhat skewed by the fact that GA craft are not built, equipped, nor maintained to the level of most professionally operated craft ... but more importantly, neither are the operators.
Rob
Rob wrote:The romantic notion of low and slow is a farce...
Zane wrote:Rob wrote:The romantic notion of low and slow is a farce...
I always interpreted that saying as pertaining to choice of aircraft, not necessarily the low end of a particular aircraft's speed envelope.
Rob wrote: Norms comment on the GA safety record is somewhat skewed by the fact that GA craft are not built, equipped, nor maintained to the level of most professionally operated craft... but more importantly, neither are the operators.
Rob
Good post, Rob, except I'd like to clarify the above part. I wasn't comparing GA safety to commercial safety. That would be an unfair comparison for the reasons you mentioned. I was comparing commercial past with commercial present accident rates and, separately, GA past to GA present accident rates. I could have stated it in clearer language ... my error in lame proof reading.
norm wrote:Over the last several decades commercial aviation has improved their accident records by leaps and bounds. Professional ops just get safer and safer.
norm wrote:Over the last several decades general aviation has not significantly improved its accident record and it remains mired in the **horrible**, or, at least in the **undesirable** column.
motoadve wrote:I read a Joe Nall report that tgere were 5 fatal accidents from LSA and homebuilt for every GA accident.
Training, low alt, and mechanicals were the main reasons
motoadve wrote:As a low time pilot myself, I understand the cables, towers and obstacles being a risk.
But when people talk about engine failure, why is it ok to fly IFR in a single engine plane,and engine failure is not taken into account as much.
I think it would be as dangerous or even more an engine failure at imc than at low altitude VFR.
M6RV6 wrote:Courierguy
I was hoping you would see some humor in my post!
GT
If not my apologies!
Great Photo and yes the tracks to find and see are wonderful!
