Just trying to get more than a couple of brains on this one, I have a capable A&P on it but would love to have your input.
Belts/Wires/etc check good beneath the light of an L.E.D. moon. After about 15 cycles spaced out a while, it was noted that about 50% of the time when the Alt is switched on, it shows good charge for 30sec-2min and then quits abruptly. The other 50% it shows nothing. Speculation is that the voltage regulator may be kaput. Engine has about 230hr since new and I assume the alternator has the same.
Plane is parked at a semi-remote field so the more ideas we have and things to bring with to increase the odds of fixing it in one shot, the better.
Thanks in advance,
SD
