I went elk hunting this weekend, I got a draw for Roosevelt Elk on BCs South coast. I had been in the area before, at the head of one of our inlets, but I hadn't remembered it being so grown up. It's been at least a decade since there's been any logging here. The bush is thick now, there are no cut blocks to look out over and no view points over even semi clear area, the elk aren't calling this late and basically you'd have to catch one on what's left of the almost grown over roads. The sign I found was old, from the spring, the elk are higher up still. I found them as I flew out, way up at the top of the drainage, about 15 miles walk from the dock, no problem to walk in but a bit of a job for packing the elk out. I'll come back when the snow falls if my draw is still open.
The flying was rough on the way in, lots of mechanical turbulence but looking down, the water was smooth and I found once I got within 200 feet of the surface things were still. On the way out it was smooth flying. The camping was a bit chilly with the water bucket freezing over at night.
The area is float plane of boat access only. As I arrived a party was just leaving with a commercial fishing boat they had been hunting from. They had brought in a couple Argos with them, no luck for them either.
My 180 at sunrise on the inlet
Camp
The logging roads
The fellas in before me took an Argo over this bridge
The views
Bit of a glacier for you ski pilots
