PapernScissors wrote:Hmmm I don't really like the idea of several gallons of avgas (or mogas either) in the cockpit with me. While an off unintended off airport landing (aka in some instances as a "crash") isn't a really high probability, bad things do happen. It seems like carrying go juice inside the cockpit just increases the odds that an event which would otherwise be just an inconvenience or maybe an incident could turn out very badly. FWIW, engines quit a whole lot more frequently than the NTSB db says they do (and the NTSB says engine problems rival LOC-I for bad outcomes). Bigger fuel tanks and more frequent trips to McCall or wherever seems a preferable alternative to bladder bags next to people.
TxAgfisher wrote:Thanks for all the info - I can only carry 40 gallons and that's only about 3hrs flight time with reserve. I may be a little over zealous but I would hope to get in 3+ hours in a day.
Bill, are you going to the SC deal again? That's what I am looking at going to in June. There's a Maule gathering in your neck of the woods also next weekend if you have any interest.
fiftynineSC wrote:Not to sound like a nervous nelly....but you are gong to get some solid mountain instruction before buzzing into the frank church correct?
TxAgfisher wrote:fiftynineSC wrote:Not to sound like a nervous nelly....but you are gong to get some solid mountain instruction before buzzing into the frank church correct?
I've been watching YouTube...
But really, I'd like to go with someone who has been before. Not really any flatlanders down here with a way to teach me anything.
Hammer wrote:PapernScissors wrote:Hmmm I don't really like the idea of several gallons of avgas (or mogas either) in the cockpit with me. While an off unintended off airport landing (aka in some instances as a "crash") isn't a really high probability, bad things do happen. It seems like carrying go juice inside the cockpit just increases the odds that an event which would otherwise be just an inconvenience or maybe an incident could turn out very badly. FWIW, engines quit a whole lot more frequently than the NTSB db says they do (and the NTSB says engine problems rival LOC-I for bad outcomes). Bigger fuel tanks and more frequent trips to McCall or wherever seems a preferable alternative to bladder bags next to people.
I don't really disagree, but if you think the wing tanks in your 172 are anything close to crash-resistant, you haven't ever seen them up close. They're MUCH flimsier than a steel jerry can. And most engine failures are actually due to a lack of go juice...
roamak wrote:I'm sure hauling gas in jugs is no more unsafe than in the wings, the reason I bring it up is the last time I hauled 100lbs of propane and 30 gallons of gas to my place. Took off at sea level and was forced to go over the Alaska range at 7 or 8000ft, don't really remember but it was high. To those who have never had a propane tank pop off while hauling gas in the dead of winter, well.....I will just stop while I'm ahead. But I will NEVER do that again. EVER. In Idaho conditions probably no big deal. Just something to think about. And yeah, I have always squeezed the air out of my gas jugs.
When that sucker popped off, my hired hand, who was following behind, said it was about the funniest damn thing he'd ever seen! Good thing I'm not a smoker. I can't imagine having that happen in the plane, good one Roamak!courierguy wrote:roamak wrote:I'm sure hauling gas in jugs is no more unsafe than in the wings, the reason I bring it up is the last time I hauled 100lbs of propane and 30 gallons of gas to my place. Took off at sea level and was forced to go over the Alaska range at 7 or 8000ft, don't really remember but it was high. To those who have never had a propane tank pop off while hauling gas in the dead of winter, well.....I will just stop while I'm ahead. But I will NEVER do that again. EVER. In Idaho conditions probably no big deal. Just something to think about. And yeah, I have always squeezed the air out of my gas jugs.
I had a filled propane tank, probably overfilled, in single digit weather go off on me while driving the road at 50 mph. It was "only" 10 gallons (?) and I had, since the rest of my small Toyota pickup was filled to the gills, put it on the passenger floor leaned up against the seat, right in front of the heater ventWhen that sucker popped off, my hired hand, who was following behind, said it was about the funniest damn thing he'd ever seen! Good thing I'm not a smoker. I can't imagine having that happen in the plane, good one Roamak
Cary wrote:On the issue of engines failing but not getting into the NTSB data base, unless someone gets hurt or there's airframe (not engine) damage exceeding $25,000, they aren't interested. All those who successfully land without doing much damage to the airplane, no matter that a $50,000 engine was cratered, won't see their names in the data base.
I have no idea how often there are successful landings without damage from engine failures, but I'm really glad that I have one!Well, actually, I'd just as soon not have had the engine failure at all, but I'm glad that there was no other damage.
glacier wrote:The lids SUCK, but if you get their newer square cut gaskets ...
The odds are good that if the engine quits (for any reason) the airplane will not only land safely, it won't arrive on the ground with any serious damage.
