courierguy wrote:Looks good Shipping costs and custom fees would change that. The Manga bladder are available state side, though French made pricy for sure, but very tough. Drop tests prove it. About 400 for 9 gallons, cheaper as you get bigger. Not repurposed but designed for ALL fuels.
Shipping is $75 AUD (about $56 USD) to me here in Canada for to total of about $216 USD. That's still a hell of a lot cheaper than anything similiar I've seen.
colopilot wrote:My question on the pillow bag is how do you fill the plane from that thing? As I understand it, the Turtle Pac has the advantage of an internal transfer pump. Unless you're capable of heaving a 150lb fuel bag up in the air and letting gravity do the work for you, I think you'd need pressure of some kind. I suppose you could attach the hose and just sit on it, but I think a pump of some kind is the most likely approach. Seems a bit complicated and messy to me, but probably cheaper.
I have a low wing, so that task would be a little easier for me (though it would be an awkward load to lift). 12 volt transfer pumps can be had fairly cheap though.
whee wrote:Years ago someone on BCP mentioned those 5gal Swiss Army water bags. Said they use them for fuel up in Alaska. I went to the local Army Surplus and bought one for like $10. Still works fine for me and I've put E10 mogas through it. I don't like the cap on it, impossible to pour the fuel without getting it on your hands, but I haven't bothered looking for an alternative.
These sound like an interesting alternative as well, collapsible, cheap, and no pump required. How are they to fill? Can they be easily filled from a normal gas pump, or is the hole too small (it's hard to tell from the pictures)? I've read elsewhere about people having issues with mogas melting the inside of the bag and putting gunk in the fuel, have you had any issues with this?
I came across this when I was googling Swiss water bags:
https://shop.tigerexped.de/Adapter-1-2-for-Swiss-Army-Water-Bag-incl-Gasket Using that to hook to a hose might reduce the spillage issue.
