All grandstanding and Machiavellian mercenary machinations aside, please fly with a shoulder harness for your safety, regardless of whether you do business with me, Hooker, Wag-Aero, BAS, etc.
From today's AvWeb -
MANDATE SHOULDER HARNESSES: NTSB
The NTSB is recommending the FAA require retrofitting shoulder harnesses in all general aviation aircraft that don't have them as the "cheapest and simplest" way of improving crash survivability. In a study that was mainly focused on the potential safety benefits of airbags in GA aircraft, the board determined that while airbags will probably help, installation of shoulder harnesses in lap-belt-equipped planes would make the biggest difference. "Based on an analysis of over 37,000 GA accidents, the Board concluded that the risk of fatal or serious injury was 50 percent higher when an occupant was only restrained by a lap belt as compared to the combination lap belt and shoulder harness," the board said in a statement. The NTSB could only find 10 survivable accidents with which to assess the value of airbags and found that of the 12 occupants of aircraft involved in those accidents, at least two of them avoided more serious injury or death because of the airbags. The board stops short of recommending that airbags be made mandatory and actually makes some safety recommendations about the design and installation of the bags, which deploy from the shoulder harness of specially equipped seatbelts.
