motoadve wrote:I have tried both in the backcountry strips in Washington where there are tall trees at the end.
VX left me high over the trees sooner at slower speed , and with the plane moving all over because of the change of winds from runway to above the trees wind and turbulence.
Ground effect allowed me to accelerate and then punch above the trees with lots of energy, this method seems more effective but , doesnt leave you options in case of an engine problem.
Which is the preferred method? Im new to the area so want to hear what techniques are used by more experience pilots .
In this case, you are comparing apples to oranges, as the saying goes. If Vx in fact "left me high over the trees sooner at slower speed", then there was certainly no need to use Vx. Why would you use Vx if it weren't in fact needed?
That is the simple answer to your question. I would never use a pure Vx climb in a situation where it wasn't really necessary, for the reason you point out, and reasons that others have noted.
On the other hand, if you had in fact been in a place that was ACTUALLY tight, a Vx climb may be the only safe way out of there. Doesn't mean you don't accelerate in ground effect....TO Vx, at which point you climb at Vx.
In the example you offered, I'd be climbing at Vy or even higher speed. All you have to do is MISS the trees, you don't have to be 100 feet above the trees.
And, if you're worried about an engine failure coming out of a tree lined airstrip, don't land in tree lined airstrips. An engine failure on takeoff from almost any of those that aren't super long (like the one in the video from Farmaule's) is going to put you in the trees anyway.
But, to me, while Vx isn't exactly an emergency maneuver, a Vx climb is something I only use when it is in fact necessary. And, in most of the instances where I've had to use it, I probably shouldn't have been there in the first place.
In your examples, it certainly wasn't necessary.
Safe aviation involves good risk management. Vx is a performance maneuver, but it does involve slightly higher risk. Well flown, it is perfectly safe, however.
If you're really worried about engine failures, you shouldn't be flying over all those trees in the first place, or you need to find a more reliable airplane.
