Cary wrote:Sorry for your loss. As one of the least qualified albeit legal tailwheel pilots around, I offer no advice other than to say I'm glad I drive a trike.
The one thing I've noticed, though, watching taildraggers land from time to time, is that the tailwheels really get a beating. Often they wobble like the wheels of a grocery cart, and I'll bet the pilot doesn't even notice that. Many planned 3 pointers are actually tailwheel first, and that seems to put an enormous strain on the stinger. Even wheel landings often result in a sudden plop to the ground, also straining the tailwheel. It isn't any wonder that every so often, the darned things fail.
Cary,
You are correct. Which is one of the reasons that we in the Alaskan Aviation Safety Foundation spent a lot of time and energy promoting the tail low wheel landing. Initial touch is on the mains, ideally with the tailwheel an inch off the ground, then at the touch, roll the plane up onto its main wheels, and keep that tail up till the horizontal and elevators can no longer hold the tail up......then lower the tail.
This technique provides slowest practical touchdown....speed comparable to three point, good visibility over the nose for obstacle avoidance, and protects that little wheel in the back.
As to pilot noticing tailwheel shimmy (you described as a shopping cart wheel....a good analogy and precisely the same physics) it's hard to miss when it happens.
But shimmy is caused by an improperly set up tailwheel, not by pilot technique.
Still no good reason to beat up that tail, and it it shimmys, you need to get it fixed.
