Just curious about this,noticeable improvements, effects on reliability and costs. ??/
gary
Av8r3400 wrote:You do know that any aircraft with forced induction (turbo or whatever) is no longer eligible for LSA rules, right?
tcj wrote:Av8r3400 wrote:You do know that any aircraft with forced induction (turbo or whatever) is no longer eligible for LSA rules, right?
Are you sure about that? I can't find it in the LSA rules.
Av8r3400 wrote:tcj wrote:Av8r3400 wrote:You do know that any aircraft with forced induction (turbo or whatever) is no longer eligible for LSA rules, right?
I thought I was. I could swear the regulation said "... a single normally aspirated reciprocating engine. ..." Now I can't find that statement, either. Maybe I eat my words.
I'd find it hard to believe that a turbo would be allowed but a controllable prop or a Cessna 150 is not. But then again, the logic behind the LSA rules escapes me in general.
In addition, if I modify my E-LSA such as adding a turbo, or any other way that deviates from the FAA certified and approved engines or instrument list or make an airframe change then it is no longer E-LSA and is booted into the Experimental Amateur Built category. It can then be flown with a PPL but not a Sport Pilot license any longer.
