jgerard wrote:Then only Helios worth having run the geared Lycoming engines. It's a long prop turning slow thing. The direct drive engines do not produce the same torque/thrust. 101" 2 blade prop for the H391 GO-435 260 hp & 96" 3 blade for the H-295/H-395 GO-480 295hp.
Jason
jgerard wrote:Yup, a few times on both H391 and H295. Makes a big difference if the guy in the cockpit knows the plane well and has the engine properly primed and throttle set right. It is a long reach up to the prop and the 3 blade on a geared engine feels weird when you pull it though. My supercub has no electrical systems so I prop it every time I fly it. I guess I'm used to it. I have heard stories of a guy propping a piston otter on floats from behind, That I would like to see!!
Jason
ccurrie wrote:heliodriver what engine does an h250 have? Is it a lycoming O-540, how do they perform? seems to me that would be a more economical setup if you dont need the high altitude performance.
denalipilot wrote:jgerard wrote:Then only Helios worth having run the geared Lycoming engines. It's a long prop turning slow thing. The direct drive engines do not produce the same torque/thrust. 101" 2 blade prop for the H391 GO-435 260 hp & 96" 3 blade for the H-295/H-395 GO-480 295hp.
Jason
It sounds like you know a lot about the topic, and I believe you probably do, but just curious- have you ever tried to hand-prop a geared propeller? A close friend of mine has with his Helio. Major bummer to kill a battery out in the b/c with that set up.
lowflyin'G3 wrote:Fly and preferrably own a Stallion.
I had the pleasure of jumping David Maytag's a time or two in 1994 both in Hermiston,OR. and Quincy,IL. Really a pleasure to have done that, didn't even care about the jump just wanted the ride.
A friend of mine in Florida leased the one that Para-Flite owned for a while around 1980. The checkout consisted of a "here it it is, see ya later". He flew it for a while and then called Larry Larmont to ask if there was anything he could do to fly it better. Larry's reply was something like"how many times have you groud looped it". Gary's answer was "none". To that larry replied "well then there isn't anything I can tell you"! He really enjoyed it and had a lot to say about the stick force augmentation system and it's helpfulness in a go around situation.
The only others I remember was the one David M. wrecked in AZ. The one Mike Mullins wrecked in Battleship park in Mobile, AL. And the one that Jim Lowe was killed in at Perris Valley (supposedly runaway trim at high speed fairly low in the descent).
I believe that someone in LA. was rebuilding a prototype airframe using parts from Mullin's wreck a ways back.
I would really enjoy the opportunity to fly one of them sometime.
One other little known fact about the Helio aircraft models was the Rattl'er which was going to be a 400 h.p. Ag plane based around the Helio wing. I believe that at least one prototype was built. This was during the period when the tooling was moved to OK. I believe.
lowflyin'G3 wrote:Gotta say as a stick driver I don't like the yoke placement in the Stallion at all. It some how seems like molesting the airframe. It makes me feel dirty, very dirty.
Next thing you know someone will put yokes in a Porter. Why do people need to reinvent the wheel? Or yoke.
