Backcountry Pilot • HELP! Airframe repair shop recommendations needed.
29 posts • Page 2 of 2 • 1, 2
Re: HELP! Airframe repair shop recommendations needed.
Another idea is to source new wings that need less/different work.
I have a set of hail damaged 170B wings - same as your 172 wings, that I’d let go for cheap.
Bagarre offline
Bagarre wrote:Another idea is to source new wings that need less/different work.
Is the electric flap setup easy to put in? Or remove if using other wings on an older bird?
UcheeCreekAviator wrote:….I am located in Auburn, AL and looking for recommendations on an airframe repair shop with a Cessna wing jig that can do the repair somewhere here in the Southeast. I have a way to transport the wings safely and am hoping to find someone that may be willing to allow me to work alongside them on the repair.
IMHO this was a smart move by the OP.
As Dirty Harry said, a man's got to know his limitations.
Better to hire the work done & learn at the same time,
than maybe blunder ahead without knowing what you're doing & fuck things up.
Bad enough when it's someone's own airplane,
but I've seen it done by an A&P charging someone else for their work.
"Often mistaken, but never uncertain" comes to mind.
I've talked to guys who attended A&P schools where everything seemed oriented toward airliners,
with very little that seemed related to working on GA aircraft.
IMHO serving an apprenticeship instead of (or in addition to) attending a school seems to produce better real-world mechanics.
An update for those of you who care
After taking some advice from some of you and researching more I have decided to take on the job myself. Unfortunately I was not able to find anyone within a reasonable distance that could work with me on the job. I've built some wing stands and am going to do my very best without a jig as one of you suggested. Hopefully I'll have the job finished in about a month. I'll post some updates here as I move along.
Once again, thank you for all of the advice!
UcheeCreekAviator offline
Aircraft: Cessna 172F
Glad to hear it!! keep us updated on the project.
Tangogawd offline
Aircraft: '62 C-180E
'69 7GCBC
Glad to hear that!!! Now, don't be bashful about asking any questions that you have as you get started!!! There's a lot of experience on here that is more than willing to help you if you're trying!!!
hardtailjohn offline
Ive got everything disassembled. Top and bottom inboard skin is off. Spars are out as well as a few damaged ribs. Ive decided to install new flap tracks and flap track track brackets.
I am going to produce the rear spars myself. The spars are made of .032 aluminum but I don't have and specs on it. I am assuming they are 2024-t3 but I cannot confirm that. Do you guys have any recommendations on where I could find that info? The manual says that 2024-t3 can be used for any wing structural repair, but it doesn't say that its a substitute for a whole part like a spar. Any thoughts?
You'll probably see a 24-ST marking on the aluminum. That's the old designation for 2024. You're doing a repair, so I'd feel comfy making the parts from 2024 as called out in the manual.
I applaud your decision to fix it yourself, but why not buy the spar channel?
AEROPOD offline
