[quote="55wagon"No damage history but alot of the tail cone reskinned. [/quote]
You have mentioned that everything is properly rigged and moving full range, but I haven't heard you respond specifically that you have figured a 0 degree reference point of the firewall/wing root and then measured the movement/ base measurement of the tail surfaces relative to the reference point on the forward portion of the airframe. The digital levels allow this to be done very easily. Do you have the measurements to post so everyone can help more effectively?
Imagine if during the reskinning of the tailcone that the upper length was made too short or the lower length too long by just a whee little bit. The tail would be producing more negative lift/nose up effect and you would run out of forward trim regardless of how much stabilizer range of movement you have because it's alignment compared to the wing and firewall is altered.
My 2c.
