NineThreeKilo wrote:I have yet to take off IFR from a lake or strip, always picked it up in the air
Personal policy for me, IFR, I won’t launch unless I can get back in, be it visual or via IAP, especially when there isn’t another close place I could get into, seeing there is no approach to most lakes or most backcountry strips, I’m not sure I’d launch IFR from the backcountry, but that’s just my personal risk matrix
Maybe if you could provide your own terrain clearance, find the closest airport with a clearance delivery phone number and call and ask
Update us, I’d be interested too
Karmutzen wrote:Pretty common in Canada. Out of controlled airspace you'd switch to a common frequency and negotiate separation directly with (any) other traffic. Descend to the sector altitude and have a look, or do your "company" approach. Same to get out, broadcast, take care of your own traffic and terrain separation, get a clearance from ATC before entering controlled airspace.
Near civilization, pretty much as slowmover describes. Call ATC by phone and get a time slot at fix or location, you're on your own until you get there, airborne call ATC on the radio and get the rest of your clearance. We'd depart in near 0/0, there was no going back.
Normal ops for bush/medvac operations.
NineThreeKilo wrote:Karmutzen wrote:Pretty common in Canada. Out of controlled airspace you'd switch to a common frequency and negotiate separation directly with (any) other traffic. Descend to the sector altitude and have a look, or do your "company" approach. Same to get out, broadcast, take care of your own traffic and terrain separation, get a clearance from ATC before entering controlled airspace.
Flew for probably the largest medevac company on earth, that wouldn’t fly with them
Safe
Legal
Prudent
Mapleflt wrote:NineThreeKilo wrote:Karmutzen wrote:Pretty common in Canada. Out of controlled airspace you'd switch to a common frequency and negotiate separation directly with (any) other traffic. Descend to the sector altitude and have a look, or do your "company" approach. Same to get out, broadcast, take care of your own traffic and terrain separation, get a clearance from ATC before entering controlled airspace.
Safe
Legal
Prudent
Like Karmutzen I've flown plenty of medevac and even more time in "uncontrolled" airspace. The process Karmutzen has outline is "standard" ops, its fully legal and can be done very safely. Canada has many, many communities serviced by uncontrolled, no tower airports from which IFR departures are flown daily.
A specific company policy may prohibit a procedure, that doesn't make it unsafe they have just chosen their own process that's all.
Mapleflt wrote:Neither Karmutzen or myself suggested departing in 0/0 conditions.
We are discussing departing from an uncontrolled airport or location in uncontrolled airspace and thereafter establishing yourself on an IFR clearance. It can be done, it can be done safely and it has been done many, many times.
Your welcome to set your own limits; within the published legal limits as you see fit, or as your employer has defined for you in their approved documentation.
Safe travels, cheers
