Backcountry Pilot • How to shoot flying video
Discuss the content of the Knowledge Base section of the site, and provide suggestions for additions.
54 posts • Page 2 of 3 • 1, 2, 3
Re: How to shoot flying video
I'm going to try the Blurfix, no joy in the local photo shops so online we go.
Got a GoPro 3 weeks ago and installed a bracket on left wing tie down ring and an cockpit inside tube mount.
Got both a Ram set up and GoPro clamp mounts.
If we get out of the deep freeze out here I can try it out. Batteries don't last long in cold temps.
Good to have an unbiased review.
Thanks
Beamer pilot offline
Zane, Thanks for this topic. I need this help :)
I have the Hero3. I pretty much always mount the camera outside which is certainly fun but watching the video you used in this topic where we can see you working the flaps, throttle, etc was very interesting. Prop distortion has always been a problem. I'll be ordering a filter as you described. I went out to the hangar yesterday moved the mounting to the overhead tubes in the ceiling behind the front seats. Easy peasy.
The GoPro seems to be about the most popular action cams out there so I'm gonna throw something out and see what all of you have to say: I've never been happy with my camera. The wi-fi has always been unpredictable. I mount the camera way out under the wing, turn on the wifi. Aim the camera with the iphone or ipad app. Maybe shoot video on take off; then turn the camera off. It may allow me to turn it on and off another time or two but invariably, at some point, I will try to turn it on or off and the camera can no longer be controlled. The camera shows up on my networks but the app with say "no camera detected" until I manually turn all of the features off and back on directly from the camera.
Second thing (everyones complaint): short battery life. Especially if the wi-fi is on (as Zane already stated). My camera may also have a charging problem (I must sound a little crazy at this point because I seem to have way to many problems to be the camera's fault right). I have the backpak battery also (i should have mentioned that earlier). Sometimes I can plug my camera in to charge (using 2amp USB wall adapter) and will still not show fully charged after a couple of days. Other times it may be ready over night. Then when fully charged, if I leave it unplugged for a week it is dead.
Are these thing normal? Am I an idiot? Am I doing things wrong?
My current intended solution is to run a USB cable inside my headliner up to when the camera is mounted and just be able to power it in flight. I tested that here in my office yesterday to make sure it would work. The camera ran until the card was full (4.5hrs) with the wi-fi on and then, when completely shut off, returned to fully charged status in an hour or so. I will say that the wi-fi connectivity did fail during that time.
Thanks,
High-maintenance-camera-nubie
Jeff
Alpina23 offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... xE66krEPHB
Aircraft: 1953 C170B
1947 Stinson Voyager
I received my possible fix for poor battery life yesterday.
http://www.aircraftspruce.ca/catalog/el ... -12101.php
No time to install or test the theory so far.
Alpina23 wrote:The GoPro seems to be about the most popular action cams out there so I'm gonna throw something out and see what all of you have to say: I've never been happy with my camera. The wi-fi has always been unpredictable. I mount the camera way out under the wing, turn on the wifi. Aim the camera with the iphone or ipad app. Maybe shoot video on take off; then turn the camera off. It may allow me to turn it on and off another time or two but invariably, at some point, I will try to turn it on or off and the camera can no longer be controlled. The camera shows up on my networks but the app with say "no camera detected" until I manually turn all of the features off and back on directly from the camera.
The wifi module has been the worst part of the software stack for a long time. Empirically, I've found things to work *much* better using the keychain remote instead of the IOS app. So I tend to use IOS for initial aiming sometimes, though usually even that I typically use the LCD backpack these days, and then the keychain. Very few troubles with that approach.
Make sure you have the July firmware. That was the first one that had a useable wifi module (IMO).
Alpina23 wrote:Second thing (everyones complaint): short battery life. Especially if the wi-fi is on (as Zane already stated). My camera may also have a charging problem (I must sound a little crazy at this point because I seem to have way to many problems to be the camera's fault right). I have the backpak battery also (i should have mentioned that earlier). Sometimes I can plug my camera in to charge (using 2amp USB wall adapter) and will still not show fully charged after a couple of days. Other times it may be ready over night. Then when fully charged, if I leave it unplugged for a week it is dead.
I haven't had the unplugged problem, so maybe you really do have a battery issue. The only other thing I can think of is that some 2amp chargers actually have multiple ports and not all of them are high power. If yours has multiple ports, just double check to make sure you are using the one that spits out the juice.
rw2 offline
Aircraft: Experimental Maule
Hello All,
I read through the thread and wanted to let you know about a mount I designed to attach a camera to a wingstrut. I have a version for all the strutted Cessnas from 140a through the strutted 210. It also works on the Stinson 108 series as well as a few experimentals using similar sized struts. I also have a version in testing that works with all 3 Bearhawks, most pipers, all of the strutted Rans, Zenair CH series as well as any experimental using Carlson aircraft struts.
I have attached a link to my youtube page as well as a few other videos. Allen uses my mount in his AOTF tv show and one of his videos is on my page.
My Page: http://www.youtube.com/channel/UCPkbgRO81PVUeH7GGwV_4JA
Video from Cubcrafters of their Carbon Cub using my mount: http://www.youtube.com/watch?v=daAFtYrfL_M
Cessna 185 in AK: http://www.backcountrypilot.org/forum/g ... mple-14210
Anyone interested in a mount feel free to PM me...
Best regards,
Marc Webster
Addicted2climbing offline
Addicted2climbing wrote:Hello All,
Best regards,
Marc Webster
And I'll be trying out the Rans strut prototype. :D Can't wait.
svanarts offline
Here's another mounting idea. I used my Nflight cam (aka Contour with prop filter) to shoot this video. I used their adjustable rotating mount and some fresh 3M double sided tape to mount the mount to the ear cup. The Nflight cam has an adjustable, rotating lens so mounting is very flexible. It really gives an eye level perspective. I had tried mounting on the headband once and like many other action cameras, the wide angle lens caught more of the roof of the cabin than action out the window, plus I kept hitting the camera on the roof. I am very happy with the results from the ear cup.
I shot the video Jan 29th in some super smooth winter air. It was cold, not as cold as it has been, but cold enough. I am basically just burning holes in the sky to burn off hours so I can take my checkride. Plus, I am still waiting for parts for my airplane. #-o I can't wait to fly it!!!!
I got a little scare on short final at the end. Made my heart rate go up a bit. I thought of mauleguy when his ratchet broke in his airplane, but this was my fault, not the airplane. I think?
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
Anyone want to supply a critique? This is my first attempt at mounting the GoPro in the cockpit. Other than being a perfect location to document the progress of my bald spot, what do you guys think of this location? Suggestions?
Also, the WiFi and controlling with my phone works awesome. Love it!
svanarts offline
Scott- That was fun. The vantage point is great but I would switch the video aspect ratio to 16:9, and get yourself a neutral density filter to totally blur out the prop.
Zzz wrote:Scott- That was fun. The vantage point is great but I would switch the video aspect ratio to 16:9, and get yourself a neutral density filter to totally blur out the prop.
The filter is on order. :) I didn't do any adjustments to the camera. Just pulled it out of the box, charged it and mounted it. When I got home I changed the video setting.
I'll also be wearing a hat next time. :lol:
svanarts offline
Scott, I like the mounting location too. I've always been a fan of showing controls as well as what's happening outside the plane in relation.
Crzyivan13 offline
I like how S12Flyer does his too. Mounted on the strut so that you can see what's ahead of the plane and still see what the pilot is doing. I'll try that when my strut mount shows up.
I finally figured out how to change the settings on the camera. Next week I'm going to try to get a little bit more out the "of the cockpit view" and still retain the panel and controls in the shot.
svanarts offline
I've always liked the cockpit view.
Magnet offline
Magnet
On several of my recent video you can see the difference between the GoPro 3 and the Drift HD170 Stealth.
All in all I much prefer the Drift to the GoPro. But that is a subject for another thread.
Someday I'll invest in a couple of filters. Probable the same "someday" I go on a diet and begin my exercise regime.
My wing strut mount is stupidly simple. Some zip ties, some high density foam and the goggle strap mount that came with my drift. Fast, easy to move, and fits any shaped strut (except round). My external GoPro mounts require much more extreme measures. The Gopro has a much larger wind profile. The only stick on 3m mount that I use is on my tailwheel strut. But I still used a short safety leash on that one. I have to use the wifi remote for that mounting so I don't use it much except for short flights. The battery life leaves a lot to be desired with the wifi running.
There has been an explosion of available mounts for "adventure" cameras so it's usually fairly easy to adapt something to nearly any part of your plane. My most recent mount is one I found on the big auction site that has a very adjustable quick clamp and a highly adjustable 1/4 x 20 standard camera mount. It pretty much will camp on any of the tubing in my cockpit. And it works with both cameras. (with the obligatory go pro adapter, of course)
What I would really like is a WiFi app to hook up to my intercom / radio. I've got enough wires, don't need a mic wire too.
My Rotax is so quiet that the only sound that ends up on my outside shots is wind noise. Not the deep throaty rumble of the Lyc's and the Conti's. So that's why most of mine have a musical sound track.
S-12Flyer offline
Hey Scott,
I received the parts I was waiting on today and will be building up some mounts throughout this week. I should have the Rans Mount ready for you in a few days.
Take care,
Marc
Cloudbase Engineering LLC
Zane,
Received my circular polarizer today. Its a polar pro glass edition.
Unfortunately, it fits a Hero3+, not a Hero3.
I didn't even know there was a Hero3+. I do now.
Anybody have a Hero 3+ and would like to buy the circular polarizer?
I'd rather sell it to one of you at half price than return it.
Now awaiting the polarizer set up you recommended in your article. One day I will listen. :oops:
Idahomike offline
Aircraft: Cessna 182D
Bonanza A36
I have a 3+ that id like to get a filter for...
Idahomike wrote:Unfortunately, it fits a Hero3+, not a Hero3.
Mike, I'm sorry for that. I didn't know they were incompatible either. I'll make the note in the article about that to hopefully prevent others from making the same mixup.
If A1Skinner doesn't take I'll buy it.
A1 Skinner..... PM me your address and I'll pop it in the mail.
How about 20 bucks... I'll pay shipping.
Mike
Idahomike offline
Bonanza A36
