I have one of these "free" seat Inertia reel "locks" under my seat in 182. Several years ago I wrote of a incident at L25 airstrip that nearly cost me my airplane and possibly my life. I have at least 3 positive seat locks on my 182 now. If I can find the post I'll put it up here . The under seat Inertia reel lock is far from perfect but another piece of safety equipment. Adjustment is tricky at best . The seat rail locks in 2 places have never let me down. Seat track and seat pins are ??? questionable at best. I start up with door open and slide front and rear seat locks in place -(and lock )before I close the door. I also leave my seat belt loose until engine starts -If I have to unass the airplane I don't want to waste valuable seconds getting out. YMMV .
Here's the original post Original was Feb. 10 ,2007 reposted april 2009 ---
Nearly lost Control
Postby 182 STOL driver » Mon Apr 27, 2009 7:41 am
Flight:
Yesterday I took a flight to the Arizona Strip -Northwest Arizona . I went north west of Grand Gulch in search of new strips that could be used to get away. About 25miles north west I found a strip very long and wide with some small buildings and shed . I wanted to mark the strip on the map so I punched the trusty SPOT (check OK ) and flew by at wingspan height. Good looking strip probably 3000 ft x 60 plus wide. Dirt of course with small ragged windsock. I was thinking of landing but decided I'd go back to Grand Gulch to have my Subway Sandwich. I flew over Grand Gulch and noticed wind was 90 degrees to main runway and blowing strong. Grand Gulch is narrow so I decided to press on to L25 -Pierce Ferry for a wider runway. I arrived at L25 10 min. or so later and landed ,wind was light and variable. I set out my lawn chair under wing and got out my sandwich/water lunch . After a hour or so the wind had picked up a little but still within reason. I proceed to the North end of the strip and dropped 10 degrees of flap in preparation for my departure. My normal departure is go full power on a roll and pull the nose up to keep the prop out of the dirt . I did and nose came Immediately I reached down and grabbed Johnson bar( now 2011 have a EZFLAP.COM handle/STC) and pulled another 10 degrees and we broke ground > just then the quartering (right to left) wind kicked in and we started toward the left hand side of runway .I rolled airplane to right to correct the "here come the bushes" and then it happened _____ THE GOD DAMM SEAT Slid Back away from my normal position. I relized that unless there was corrective action soon it was going to be all she wrote for me and the 182. There I was nearly in back seat trying to pull my self forward -I garbed glareshield (thanks Dennis Ashby ) with my right hand to get me back in position. I was now 8-10 foot off the deck 40 knots and hanging on ! Lowered the nose and gained some needed airspeed and started to see some increase in altitude. Shifting my butt around and trying to lock the Cessna seat took another second or so. I was off the airport runway but Downtown Meadview was ahead. I thundered down toward the biggest part of trailers . I gained 2-3 hundred ft. and looked ahead to see a big tower overlooking "city center fire station"
I turned to the side and continued to climb . Old airstrip in Meadview still has a wind sock and a few airplanes about. For what's it worth I'm buying or making a new and stronger seat lock to prevent this from ever happening again.
Of course I now have more seat locks to hopefully never have this loss of control. Pilot seat is only one with Inertia Reel -all others have at least 2 or more locks. I have 206 seats in back (when there there)with seat rails (thank you Kenmore Airharbor STC) with 2 locks each. I take all of the seats out and load my "stuff" and only put what seats I need for the "mission "back in. When flying Idaho I have one pilots seat and one 206 seat for the back. Remove the doors for easy access and loading "stuff"-alternative is "skydiver-floatplane door(s).
