Backcountry Pilot • Inertia Reel for Under Seat C182
36 postsPage 2 of 21, 2
Re: Inertia Reel for Under Seat C182
kevbert wrote:
Terry wrote:
kevbert wrote:Free through June 15, 2012. Service bulletin here:
http://www.cessnaservicebulletins.com/Bulletins/SEB07-5-R02.pdf
And, for the record, I hate mine.
Curious why you don't like it?
The thing occasionally sticks so I can't slide the seat back when trying to get in or out (not sure, but might be temperature related). I previously was in the habit of keeping things under my seat (fire extinguisher, pistol, lunch, etc.) that don't fit now. And, I was initially under the impression that Cessna was fixing something now due to legal pressure that was so rare that it hadn't really been a problem for the last 50 years.
I'm starting to hear occasional stories about people sliding back unexpectedly, sometimes pitching up due to the sudden pull on the yoke. There might be more to the problem than I first believed, so I've decided to keep the stupid thing and just curse it for the emotional release. Stupid bleeping reel is taking almost a six pack out of my useful load!!!
Cessna has now started paying for the copilot's seat as well, something they didn't do when mine was installed. Has anyone decided to go for or against installing it as well?
Kevbert,
I'd get a mechanic to VERY CAREFULLY verify the rigging of the thing. As Mr. Reid noted, getting them adjusted right is a little tricky. I suspect what's happening is either the connection from the seat latch to the reel isn't adjusted properly, OR on those occasions when the thing wouldn't release, it's quite possible that you released just the slightest bit of pressure on the seat latch release handle. The inertial reel release is connected directly to the seat release lever.
On mine, if I don't get that seat release lever pulled ALL the way up to its stop, the inertial reel won't unlock. I believe that's the way it's supposed to be adjusted.
I'd bet on the latter, but it's possible it wasn't adjusted just right when it was installed.
If I remember correctly the SB states that pin must be at least .050 above the track to release the restraint, I have seen other aircraft that are adjusted to take far more clearance to release, this is why some require the seat release pulled hard to release or don’t release properly. Check the installation instructions. If the reel was installed correctly there is adjustment in both directions at the end of the cable where it mounts to the seat bracket.
172heavy offline
Mine has always worked flawlessly as long as you pull the seat release all the way up. A 6 pack weighs at least 4 1/2 lbs I really don't think this device weighs more than 1/2 lb [-X
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Are they doing that for sure?
I worry about cam locks for passengers in an emergency.
The other thing with the Areostop cam locks I use is you loose a couple inches of seat travel to the back.
Terry offline
I was repeating what another pilot told me, but tonight's research doesn't back it up. According to the service bulletin, they give credit for the pilot seat subject to some various conditions. It doesn't mention the copilot seat. Sorry!
kevbert offline
58Skylane wrote:What is everybody's opinion about an AD ever happening in the future? That's been my worry. If I don't take advantage of having Cessna pay for it now, with my luck an AD will come out later down the road. Then I'm stuck with the bill. Guess I should just get mine installed.
So...... does anybody have any thought about a possible AD in the future?
Guess not :?
Why doesn't somebody make a decent seat rail for a Cessna that doesn't require all this crap?
Bonanza Man offline
Hello,
Some of you will recognize me from Supercub.Org. I've never posted here but stumbled upon this topic and it grabbed my attention so I thought I'd fill in some blanks for those who haven't installed the Cessna supplemental seat lock. I own and fly a 180J and like most Cessna pilots have used a seat rail lock for most of my ownership years. A couple of years ago I had a start-up engine fire and found myself stuck in the seat because in the commotion to get out of the plane, my seat jammed my Aerostop. That was an eye-opening experience, being stuck in a burning plane. Now I have Cessna's locking reels installed on both front seats and the Aerostops are retired. Let's talk about a few statements I've read in this thread. First, the reels are not inertial. They are normally locked reels that can be released by a cable control that connects to the stock seat adjustment linkage upstream of the locking pin. Lifting your seat adjustment control simultaneously retracts the release cable.Until the cable is retracted the reel is firmly locked. It is a fail secure system. For the guy who says his reel doesn't release properly? Take about 30 seconds with an open end wrench and adjust the cable length. It's done at the cable bracket that attaches to the seat. The cable is shortened or lengthened by adjusting two jam nuts on the cable housing. Very intuitive. Incredibly simple. Properly adjusted the release mechanism is invisible and undetectable to the user and it works perfectly. Should you have it installed? On Cessna's nickel? Hell yes you should. And then you should insist that they install one on the right seat on your nickel. Your passengers are more likely to improperly lock the seat than you are and are also more likely to respond improperly by grabbing anything they can reach if their seat slides back. What'll they grab? The control yoke. My wife, a regular flier, has demonstrated that to me a few times through the years. It's my belief that potentially fatal aft seat motion is the result of improper locking rather than seat pin failure. Trust me, the right seat needs a passive safety lock. Somebody asked why nobody make good seat rails? Cessna and McFarlane both make excellent seat rails, but nothing lasts forever. The youngest 180s in the fleet are approaching 30 years old. The early models are approaching 60. Most probably have original seats and rails. Locking holes wallow out. Rails crack from stress and wear. And the Cessna seat locking pin is also suspect. Especially as the tip wears. Speaking of that, didn't somebody ask about seat pin failure? I had my pilot seat locking pin break this summer, and I mean break in two. It wasn't what I expected, either. When the seat pin broke the seat didn't slide back like all the stories tell you. In fact when the seat pin broke the broken piece separated from the main pin and could no longer be lifted from the track hole to release the seat. So in fact the seat couldn't move at all, which troubles me as much as having it move against an auxiliary lock. I climbed out and investigated. After I removed the broken pin I found the seat reel 100% effective in controlling the aft motion of the seat. The new seat pin, a ridiculously simple piece of metal, cost me $350. Also consider that seat rail wickets and pedestal legs can break, and rails can break. Guess what? The lock reel will arrest seat movement from those failures, too.
Like some others around here, I lost a friend last summer in what was a horrible crash. It took the lives of Lonn Greiner, his kids, and his mom. It's been widely speculated that the accident may have resulted from a seat failure. Maybe yes, maybe no. But a maybe that killed 5 people that I knew is good enough reason for me to ask all of you to take a simple and inexpensive step to prevent that maybe from happening to you and yours. If you have a lock, bravo. Please consider adding a second one. If you haven't added them, please consider doing so. Your flow chart that includes a manual rail lock is not a reliable solution. The Cessna reels are the best supplemental seat lock available, hands down. When somebody invent a better one, I'll be first in line to upgrade.
If I knew how to post pictures I'd post a few. The reel is made by Amsafe, the big guys in the aviation restraint business. I have a shot of the reel installation. I also have photos of the cable adjustment mechanism, and of a handy clevis screw for no-tool removal and installation of the seats. I'll try to figure out how to post pictures. If you're on the fence about this safety mod, perhaps they'll help alleviate any concerns you might have. Stay safe.
StewartB
stewartb offline
Pictures.
#1- the reel as attached to my right front seat. The attachment to an articulating seat is different and my articulating seat also has a fire extinguisher attached between the front legs. Cessna took no exception to the extinguisher being there and routed the strap as necessary. #2- The cable attach bracket and adjusting nuts. Just like your old bicycle brakes. Very simple to adjust. #3- The standard attachment to the floor. Cessna installs a nut plate in the floor to attach the belt to. This photo is taken with the seat in the full aft position. The belt does not get in the way. #4- A stock Cessna jump seat attach bolt used so that seat removal/reinstallation doesn't require a wrench. I remove seats regularly. This makes it easier.
One motion to adjust the seat, in good times or bad. That's a big deal. When the shit hits the fan, one motion is all you can handle. And for unfamiliar passengers? Rail locks are just plain dangerous. That statement is based on experience.
stewartb offline
Good to see your pictures.
Stewartb, I never looked closely at mine before. Groan... I can't believe I've been fighting it for this long! I took a careful look at it this morning, and it definitely needs a minor adjustment. Maybe I'll hate it less now! :D
Thanks for your post!
kevbert offline
stewartb wrote: Somebody asked why nobody make good seat rails? Cessna and McFarlane both make excellent seat rails, but nothing lasts forever. The youngest 180s in the fleet are approaching 30 years old. The early models are approaching 60. Most probably have original seats and rails. Locking holes wallow out. Rails crack from stress and wear. And the Cessna seat locking pin is also suspect.
I had a 182 for a while and there was always a worry about the damn seat rails. Sold it and now have a Beech, nobody ever talks about seat rails and they look essentially the same as a Cessna rail. How about Pipers and Mooneys, you never hear about them? Had a new carpet installed this week so got a pic of my seat rails.
http://www.flickr.com/photos/newps/6484 ... hotostream
Bonanza Man offline
I'm not qualified to comment nor do I care to speculate on seat rails other than those in the models I've owned, operated, and have become familiar with. My interest in this thread is centered on the Cessna supplemental seat lock.
stewartb offline
All the new generation Cessnas have the latest and greatest seat rails, ala Caravan. Problems solved, I assume, although, as Stewart says, EVERYthing wears out after a while, and seat rails take a beating.
stewartb wrote:I'm not qualified to comment nor do I care to speculate on seat rails other than those in the models I've owned, operated, and have become familiar with. My interest in this thread is centered on the Cessna supplemental seat lock.
Well, if you've been around here long enough, you would know that some of these threads like this one branches out to become a bigger family tree than a Kentucky/Tennessee family :D :lol: :D
