Also curious what you guys think of my temp spreads? Is it super important to have them tighter then that? If so, what does tighter grouping give me? Longer engine life?
Thanks.
This is an IO-520. Very close to LOP. But I'd be happy to run it at less. I can get about 10.7 GPH but it is not Smoot at that anymore. According to the lean find feature 11.5 is LOP. I've been very happy with that economy and setting when comparing with the same engines that have GAMIs and tuned exhaust. Our numbers are very close, although their temp spreads are a bit tighter.Squash wrote:My experience with the big six cylinder continentals is that the forward cylinders run hotter and the rear cylinders run cooler. My hottest cylinder is usually 5 which sits behind my oil cooler. Also, you are running your engine in an interesting way with your fuel flow on the low side for ROP operations and on the high side for LOP operations at that MP and RPM. Or are you running a 470?
Based on your questions on temperature spreads and longevity, I believe you might benefit from the course by Advanced Pilot Seminars. https://www.advancedpilot.com/
I'm not running Gamis. I have swapped injectors and it didn't make any noticeable difference. I guess that's maybe my real question. Are my temp spreads close enough? Or should I invest in Gamis to get them closer. It's a lot of money to spend if all I am doing is bringing my spread closer for nothing more then visual purposes. If it will help my engine last another 500hrs then it's worth it, if it's just to level out my bar graph I'm not sure it is...m_moyle wrote:I’m curious...are you using Gami injectors? If not have you tried swapping the hottest cylinder injector with the cold cylinder?...And what is the minimum CHT for lead precipitating and fowling the plug? Impressive fuel flow rate! The IO520 permold I built for my experimental has no RPM restrictions with the prop counterweight configuration.....it has Gami’s...hope once the Bearhawk is done my flow rates are as good as yours...
Sent from my iPad using Tapatalk Pro
Tangogawd wrote:I have never seen the back 2 ever being close to cold..... I would "trust but verify" that the probes are where they say they are. Heat gun to the probes should do the trick.
GAMIs are intended to balance EGT(for better LOP operation), not CHT.
Hey Corey. I'm at 5500 on that flight. It was a winter flight so probably why it's a bit cooler. Up at 7500 I can get it down to 10.4 usually.Grassstrippilot wrote:Get Gamis! They are worth it. At what altitude are you seeing that “LOP” fuel flow? I question if you are really lean of peak. LOP in my IO-520, I’m seeing 10.0-10.5 gph around 5-7k’ decreasing to low 9s to high 8s above 10K’. All temps in the mid to low 300s unless it’s winter time and then a few dip into the high 200s. If I remember eight you don’t want to get them colder than 27-280. I forget the exact reason. Something about the lead scavenging or something. Watch Mike Busch’# videos on leaning and his follow up on LOP ops.
Lower CHTs do extend life via lower internal pressures, temps, etc. mike covers this stuff too. For $900 gamis are a must, especially if you want to run LOP.
A1Skinner wrote:So I have 110hrs on this engine now in my 206. The rear 2 cylinders run consistently cooler then the rest. Seems to be the reverse of what usually happens. Any ideas on that?
Thanks
Scolopax wrote:
I don't know if there are any adverse results for having CHTs down around 270F, but I believe that the properties of most steel and aluminum alloys are pretty stable in th2 200-400 range.
They warm up if I run full rich, but they still aren't the hottest ones.[email protected] wrote:Hello A1
Curious, did you try running your engine rich as Squash suggested to see if your rear Cyl became the hottest ones?
This is at 5500 feet the other day. Still running nice and smooth at this setting. 40 degrees LOP.Grassstrippilot wrote:Get Gamis! They are worth it. At what altitude are you seeing that “LOP” fuel flow? I question if you are really lean of peak. LOP in my IO-520, I’m seeing 10.0-10.5 gph around 5-7k’ decreasing to low 9s to high 8s above 10K’. All temps in the mid to low 300s unless it’s winter time and then a few dip into the high 200s. If I remember eight you don’t want to get them colder than 27-280. I forget the exact reason. Something about the lead scavenging or something. Watch Mike Busch’# videos on leaning and his follow up on LOP ops.
