IO-520 cylinders #1&2 running cool
I have GAMIs on my 520. #1 & 2 are my coolest CHTs as well.
On #2, 4 & 6 you can change the CHT distribution significantly by playing with the height of the front baffle. I still have aluminum tape on #6 that raised the #6 CHT and cooled #2. The result is dramatic, and fairly linear. IOW, if you add some tape to raise #6 by 30f, then it will drop #2 by roughly the same 30f. One of these days I’ll install a permanent baffle there.
Cannon offline
282
- Aircraft: C-185
Piper J3C-65
Pitts S1S
[email protected] offline
151
- Aircraft: Cessna 180 Skywagon
Sun Jun 06, 2021 11:21 am
Cannon wrote:I have GAMIs on my 520. #1 & 2 are my coolest CHTs as well.
Ok, thanks Cannon. I'll try lowering my front baffle a bit.
5218
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
I know this may not be your problem but an acquaintance was chasing CHT’s using his JPI monitor on a big bore Continental and we found that the “mechanic” that installed the monitor used Lycoming’s cylinder positioning. Just verify yours is installed correctly before wasting a lot of time.
Screamer offline
7
- Aircraft: Stanley Screamer ( One off)
A185E
