Trying to take pics to document my progress.
I think I have finally collected enough parts to get it done!
Crank case half.
Rod set with bearings and bolts.
Crankshaft with rods installed.
Thread on case half.
PAMR MX wrote:Cool! What kind of machine is this gas burner going to drag through the ether?
Headoutdaplane wrote:Um......i think you need to use "we" don't forget the work I did on the engine.
SixTwoLeemer wrote:Where did you send the cases and crank out to? How much?Inquiring minds want to know…
What cylinders will you use?
Looks fun-
182 STOL driver wrote:PAMR MX wrote:Cool! What kind of machine is this gas burner going to drag through the ether?
From the pictures on his web site and gear in back of Crankshaft picture I'd say motor is going into Cessna 205 or maybe a 180 with fuel injection.
I wire tied a piece of dowel to the 3&5 rods to hold them in place then lifted the crankshaft by the #1 rod and the prop hub to place in crank half.
180Marty wrote:I wire tied a piece of dowel to the 3&5 rods to hold them in place then lifted the crankshaft by the #1 rod and the prop hub to place in crank half.
I've always wondered why people do this. Why does anyone want to deal with rods flopping around. When I did my O 470 K, the case was put together and torqued with the rods installed later. When I topped my 470 A on the plane, I put new rod bearings and bushings in too.
182 STOL driver wrote:On pictures of Crankshaft -I see a spot on main where plating is off -or is it a spot on camera lens ?
Yeah, people do them both ways.
180Marty wrote:Yeah, people do them both ways.
Hope you didn't take offense. I'm with Hotrod, keep the pic's coming. I've never dealt with an oil transfer collar yet, just the big, simple, front main that goes with a Phase 1 case.
