Backcountry Pilot • IO470 Engine Build
IO470 Engine Build
31 postsPage 2 of 21, 2
Re: IO470 Engine Build
Battson wrote:Awwesome! I will continue following this!
Do you know why the crank end-gear has to be heated so much before torquing? I assume its something to do with being at operational temperature with the correct torque, but it seems like it would be easier to calculate the adjusted torque value? Or perhaps is more about getting the fit with expansion?
It fits tight on the crankshaft end!
Heat makes it go on easier!
Also with that type of gear (new style) you have to run a shim on the starter adapter for clearance.
TangoFox offline
Keep the Greasy side down!
Quit being lazy, post more
Headoutdaplane offline
www.belugaair.com
Tango, PAMR MX doesn't seem to be answering my question on the oil transfer collar. Is that a shim on the right case half with the two screws. Does it have to be measured to get just the right push on the collar? Thanks
180Marty wrote:Tango, PAMR MX doesn't seem to be answering my question on the oil transfer collar. Is that a shim on the right case half with the two screws. Does it have to be measured to get just the right push on the collar? Thanks
Here is a link to the service bulletin for the transfer collar.
http://www.tcmlink.com/pdf2/M78-3.pdf
TangoFox offline
Headoutdaplane wrote:Quit being lazy, post more
Okay Okay!!!! Take it easy!!! :D
Oil pick up tube in place.
Oil pan (please excuse the paint defect) :oops:
Accessories
TangoFox offline
Push rods and rockers installed!
Valve covers and Injector tubes done.
I will flush the fuel system when I install it also.
The meat of everything is done!
Now just waiting on Ignition system.
Install a few brackets intake and exhaust systems and make some noise! 8)
TangoFox offline
Nice!
Accessories
It's nice to see that they are gold plating some of the accessories now. For the price it's only fair.... :D
Mister701 offline
Aircraft: Rans S7LS
Accessories
Yep makes a guy feel a lot better about it!! :lol: :lol: :lol:
TangoFox offline
She looking "...Mighty mighty, letting it all hang out..." I see a lot of strong ponies those cylinders!
8GCBC online
Awesome, thanks for posting pics, looks great!!!
Skalywag offline
