Thanks.
All of those links are helpful.
A TSO in itself does not approve an instrument for installation - makes sense.
AC 21-50 4.a states that along with the TSO, you need to show the device to satisfy other relevant airworthiness requirements.
I'm guessing the relevant airworthiness requirements would be listed in the regulations the aircraft was certified under? In my case, CAR3?
So along with meeting minimum requirements (being TSOd) it need to also comply with CAR3?
AC 21-50 4.b.2 wrote:To the extent that the FAA-approved TSOA data aligns with the applicable airworthiness
requirements, the data needs no further substantiation or evaluation by the FAA.
So if the the TSO documentation for a device shows it complies with CAR3 requirements - it's approved for installation (No further substantiation or evaluation by the FAA).
AC 20-41A 6 . Specifically excludes AutoPilots and other things including wheels and tires... and says
AC 20-41A 6 wrote:Substitutions which affect equipment in the cockpit should be evaluated by appropriate flight test personnel.
What/who are appropriate flight test personnel?
What sent me down this path is the Sandia SAI 340 which carries the Altimeter, Airspeed, Artificial Horizon, and a few other TSOs.
If the device is TSOd for those functions and satisfies CAR3 requirements for airworthiness - Why can I not install is as my primary flight instruments?
I can't find where it says it can't but everyone I talk to says it can't be done.
Another example is the Aspen Evolution. They have a landscape version that is TSOd the same as their portrait versions but the landscape version is marketed as a Backup. When I asked Aspen, they told me there is no difference in the two except for the orientation.
The Garmin G1000 carries the same TSOs for Airspeed, Altimeter and other primary instruments as the Sandia SAI 340 (from what I can tell).
What makes one primary and one not primary?
