Dealing with engine failure in single engine aircraft is one of those things we practice in training, check rides, and BFRs. Engines fail for a lot of reasons. Mechanical problems, operator error, fuel issues, and ice have all been the root cause of aircraft accidents. The NTSB aviation accident data base only has data on the bad outcomes of losing an engine. That means it understates the 'real' number of piston engine failures in single engine aircraft. Whether the NTSB data is 'off' by a little or a lot is unknown. Could the relatively small number engine failure accidents in the NTSB data base perpetuate a myth of engine reliability? Do most pilots who lose power in a Fixed Wing, Single Engine, Factory Built aircraft avoid bending metal because of skill, luck, or both?
Based on my own experience, and that of pilots who have responded to this survey elsewhere it looks like the NTSB accident data isn't a good estimate of the number of power loss events experienced by pilots. Respondents to date report that only about 1 in 5 pilots who lost all power (for ANY reason) experienced an NTSB reportable accident. Partial power loss seems to result in even fewer NTSB reported accidents.
Would you invest just 5 minutes and share your own experience by completing this survey? Sharing your experience with piston engine reliability will help us all better prepare, and perhaps reduce the number of engine failures that ever become accidents.
https://www.surveymonkey.com/r/NF92626
Please complete the survey even if you've never experienced the sounds of silence from your piston engine.
The survey has just six questions. I ask about your overall flight experience, then focuses on your experience in Factory Built, Single Engine, Fixed Wing, Piston Powered aircraft... like the Cessnas, Maules, and Pipers, etc. that most of us fly. However, I also ask about your experience in other airframes (EAB, helicopter, glider, jets, ME piston, turbines, balloons) since this is a good indication of proficiency and overall experience.
Please take just five minutes and share your flying experiences. Please respond to the survey, regardless of whether you have ever dealt with a complete or partial engine failure.
Using data you provide I will estimate the ratio between the frequency of engine failures we have collectively experienced, and explore how often a piston engine failure might result in an accidents or incident. I will also use data from the survey in FAASTeam safety seminars and webinars, SAR training, and in articles.
Again, even if you have never, ever experienced an engine failure please participate in the survey. It’s important that the data set include the experience of pilots who have NEVER lost their engine, as well as from pilots who have had multiple "opportunities" to demonstrate proficiency with emergency procedures.
FWIW, the National Transportation Safety Board reports that in 2012 loss of power was the second highest cause of accidents. Take a look at the part 91 graphic in the 2012 report titled "Defining Event for Personal Flying Accidents" posted under Data and Stats on the National Transportation Safety Board website at http://www.ntsb.gov/investigations/d...20Summary.aspx
I much prefer the boredom.
