JP256 wrote:For comparison purposes, you would need to then run an equivalent survey about automobile engines. I personally have never had an aircraft engine fail, but have had multiple failures in cars and motorcycles.
I've only had one power failure and it was in the pattern. I think the reliability of our GA engines has room for improvement as with many things, but that doesn't mean they're unreliable per se. In fact, I find the reliability pretty impressive for what our standard engines are.
A tid bit off topic but worth mentioning on the note of auto engines... a couple acquaintances and I talked about auto engine reliability a while back. There are plenty of auto conversion aircraft. Some work great, some don't, but there's one auto conversion that stands out as it's own entity; Mazda rotary engines.
I'll admit, finding/making a good PSRU (prop speed reduction unit) is probably the biggest challenge for rotary conversion aircraft, but tons have done it, few have any major issues. The parts count of a Wankel engine, even including the planetary reduction drive, is immensely lower than that of the piston engines, plus, one of the most popular piston aircraft engine choices, Rotax of course, runs with a gearbox.
Rotaries have been making their way into aviation quietly and slowly, and proponents of the rotary claim it runs smoother, has a much better power to weight ratio, and a fuel consumption rate that has improved immensely over the many decades of research, machining, and material technology. Rotaries got a bad rap a while back especially with the apex seal reliability issue, and the housing chatter/wear problems, plus it's understandable that they're not the best candidate for cars. Although they have weakness on the road, they have strengths that shine in the air. Most of the "stereotypical rotary issues" such as the ones mentioned above have been solved with time over the past couple decades.
There are a couple companies working on rotaries for aircraft such as Mistral in Switzerland and Austro (Diamond aircraft) in Austria. The prices are a bit of a shock for now.
I definitely understand those who wish to stick to what they know and love, and that is just fine with me. I've owned three piston powered aircraft and I don't have much to complain about (well, nothing serious/anyone else who owns a piston engine wouldn't also complain about
I recommend checking out some of the internet resources for aircraft rotaries if you are looking to kick the pistons and try something different and, believe it or not, relatively proven (compared to
some other auto conversions). I know a few guys that have 1000s of hours behind rotaries and they're doing just fine. Care and feeding isn't too dissimilar to what we're used to.
Every engine's got it's pros and cons. I wouldn't hesitate to fly behind (or in front of) most standard GA engines, so long as the maintenance, love, and care is there. Neglect any engine and it's bound to bite you.
Sorry for rambling.
