whynotfly wrote:I want to purchased one of these portable jump starting units to carry in my plane in case I find myself with a hard starting engine and a worn down battery in a remote spot. I'm not a real wiz when it comes to electrical topics so I thought I would ask you folks before I shell out $$ for something. Having done a little bit of searching it seems I have two basic type choices, the somewhat bulky ones you find at your neighborhood auto parts store and then the new lightweight lithium units. My plane is a 59 172 with a newer Lycoming 0360 A1A which uses an alternator verses the original generator. It is a 14 volt system. I am a little wary of the lithium type due to possible fire hazard. Are my worries valid? I am leaning towards getting one of the regular automotive type with 1000 amp available for jump starting (about $80-90 with weight of 18lbs) which I could carry in the baggage compartment. I would appreciate any input from those who have used these or carry one of these in their plane. Thank you in advance. John
The following applies more to people with a -540 or -550 engine, but FWIW:
I have been burnt by light weight batteries before, and learned a lot about them in the process. Basically, if it seems to good to be true, it probably is.
I think it's the pulse hot cranking amps PHCA, rather than the cold cranking amps CCA, which matters in these small power pack units. Let me explain - how many amps it can sustain at freezing temp for 30 seconds isn't the most relevant measure of performance with our large bore engines, it's the electrical in-rush in the first second which creates the largest drain on the power pack (battery or jumper). If it can't support that amperage, the power pack's voltage will collapse, and the prop stands still.
For example, take the Oddessy 680 model we know and love.
It's CCA rating is 170, easily matched.
It's PHCA rating is 520 amps for 5 seconds (wow!).
That is what starts a big engine, sustained pulse cranking power, but 520 is only *just* enough to start a -540 with very cold oil and high compressions.
If your power pack doesn't provide enough PHCA to turn over the engine past the first compression stroke, from a standing start, then the other 29 seconds of CCA are worthless to you (that's what CCA is, 30 seconds of current). Personally, I would strongly suggest doing a test start with any power pack you buy (if you didn't already) before lugging the thing around with you. If they don't post a PHCA or CCA number, be dubious until proven otherwise.
You can parallel a jumper pack over a partially flat battery (or a good battery) to get more juice out of the whole system. But it's worth being aware that unless both the jumper unit and your battery have the same impedance, one could get worked a LOT harder than the other. This could potentially damage an already weakened battery, particularly a high performance model like an Li-Ion which may not survive a deep cycle below 60% discharge.
