AKclimber wrote:Umm, your ASI is in mph and your tape converts it to mph as if the ASI was in knots.
I think he's referring to the paper at the bottom of the photo... I believe the white window in the ASI would be the TAS tape...
Gabe
ebag wrote:AKclimber wrote:Umm, your ASI is in mph and your tape converts it to mph as if the ASI was in knots.
Gabe
CAVU wrote:I worry less about a satellite apocalypse than I do about batteries and electrical gremlins. I subscribe to Foreflight but still buy sectionals for big trips in case the iPad dies while I'm over unfamiliar terrain out of range of the ever-thinning number of VORTACs. I've had iPads shut down from heat and I've also had them down in the single digit percentages of battery with the display turned way down low after a 4 hour flight, even with a recharging brick.
I keep the charts with the E6B in the side pocket. I have two GPSs now, but I've also had enough electrical gremlins over time that I want paper with me when I'm traveling. When it comes to pilotage, knots are easier.
CAVU
courierguy wrote:
MPH for me, my plane is slow enough.
Hell, I still carry one of the old style Flight Guides! Full of personal notes (a good close gas station, or bar or restaurant, here, my own travel guide). And how would I shade my windshield when tied down, without a paper sectional? Not to mention the (thankfully) very occasional use after taking a crap somewhere and then realizing the planes TP supply was gone. OK, I think I did that one time.... There is nothing more embarrassing then to call out a runway heading a few times as you set up a landing, and then realize as you get over the numbers, that due to the earth's wobble (or something like that) the numbers have changed! You may as well just broadcast in the blind, "I have old out of date info and am a dumbass."
contactflying wrote:I'm not a proponent of integration of instruments with contact flying, but GPS has made the choice of knots vs mph somewhat irrelevant. IMC, decrease in either means pitch up more accurately than artificial horizon. Increase means pitch down. We mostly are radar contact now so don't have to estimate compulsory reporting point to within three minutes.
Extra kinetic energy of staying in low ground effect doesn't care. Zoom reserve doesn't care. Target to target navigation, with two hour potty stops, doesn't care. Apparent rate of closure doesn't care.
Aryana wrote:We should all switch to feet per second!! That's the conversion I'm usually doing when off airport. It makes me visualize how hard and how far a bad hit would be.
1.5 x mph is a close approximation.
Bagarre wrote:Aryana wrote:We should all switch to feet per second!! That's the conversion I'm usually doing when off airport. It makes me visualize how hard and how far a bad hit would be.
Meters per second, if we want to join the rest of the planet.
Hammer wrote:Bagarre wrote:Aryana wrote:We should all switch to feet per second!! That's the conversion I'm usually doing when off airport. It makes me visualize how hard and how far a bad hit would be.
Ummm...pretty sure it's meters per metric second...sorry for making you look ignorant.
dogpilot wrote:The reason we use knots has become somewhat obscure. Before the days of magenta lines on screens we actually had to use paper maps. Sometimes we did this in places that had no actual navaids. So 1 nautical mile was one arc second on the map. So we could dead rekon our position with some idea of where we might be. The nautical mile actually represented something we could relate to, not a wavelength of a hydrogen atom, or three barleycorns, which I never seem to have available when I need it.
So, while MPH might seem marginally useful, when all those satellites go dark from a solar storm or some pissy conflict when the powers decide to switch them off. Be thankful you have knots, you may need it someday...
aftCG wrote:….Paper charts rock. Try beating the stuffing out of a yellow jacket with an iPad when they come out of the wing root vent.
hotrod180 wrote:aftCG wrote:….Paper charts rock. Try beating the stuffing out of a yellow jacket with an iPad when they come out of the wing root vent.
"More than once" needs to be added to that.
whee wrote:A few things got me thinking about this. First was a fairly precise discussion about landing technique in my airplane. Some guys talking in knots with others in mph. It made for a convoluted discussion because you can't just SWAG the conversion when your talking about 30kts or whatever speed puts you on the cusp of a stall.
