1959 c150. Plane went into annual a couple days ago. Looks like the gearbox is knackered and the fix is $10k+. I figure the airplane is worth about $15k, and the o-200 has about 1600 on it. So some life left, but looking at overhaul in the next couple years. Here's the most recent email from our A&P, any of you guys see a way out of this?:
How hard is it to find a tailwheel STC+parts for an early 150 these days?
"I never did hear from Beegles today, with a quote. I did talk to Yingling, the big Cessna place in Wichita. They said that the labor for the landing gearbox repair would likely run to at least $10,000. Not sure how much parts would be, but probably at least a few thousand more.
That said, Yingling is likely to beat the high end, price-wise. You might very well find someone who would do it for much less. Martin suggested getting in touch with the Cessna owners club, as someone else has likely been through this, and might have some insight into best options.
You could also consider converting it to a tailwheel. That would eliminate the use of those cracked pieces, but would also costs thousands of dollars.
Of course, there is always the option of selling it as a project to someone else. You'll take a big hit, but certainly a smaller one that the money you'd put into it repairing it.
By the way, one item that I didn't put on the spreadsheet is that your wing attach bolts are fairly corroded on the outside. They're almost certainly fine in the parts that I can't see, which are the ones that count, but technically, they should be removed and either inspected or replaced.
I'm very, very sorry that the news is so bad. If you'd like to go over all the items on the spreadsheet, let me know. I can give you a call, and we can go through it line by line. Also, if you're talking to other folks about the cracks in the landing gearboxes, and need some visuals, I have a paper document that shows these areas on another 150. I can mark it up with where your issues are for you."
I'll let you know when I hear from Beegles."
