Rob,
Ya might want to make sure you are not underinsured on the value of your airplane. Not many Maules these day’s that can be had for 120k.
Flyhound wrote:I ....I don't know what your mission is, but the MX7 with the 180 Hp O360 has been ideal for me. I have 1,015 pounds of useful load, but I have to be careful with where that weight is placed. I can't put 2 adults in the back seat because of an aft CG problem. Losing the weight of 2 cylinders and some case metal off the front of the airplane will do that to you (the Maule was designed for a 6 cylinder engine). On the plus side, losing those 2 cylinders has reduced my fuel burn, made my maintenance costs a bit lower and still has provided an airplane that has taken me everywhere I want to go. ....
asa wrote:If the prices between an M7 and M5 are similar, definitely go M7. <...> M5 wingspan is 2ft shorter than M7, and a lot less flap both in span and in deployment angle.
G44 wrote:Ya might want to make sure you are not underinsured on the value of your airplane. Not many Maules these day’s that can be had for 120k.
G44 wrote:Rob,
OregonMaule wrote:G44 wrote:Rob,
Thanks Kurt, you're right. It is probably time to bump it up.
1:1 Scale wrote:OregonMaule wrote:G44 wrote:Rob,
