M6RV6 wrote:reading some comments on another page.
Food for thoooooooooooooooought on blaming the Old Guy!!
Several commenters stated that “skydivers always have right of way over aircraft, so the (87 year old) pilot is obviously at fault”. I couldn’t remember reading about skydivers having right of way over aircraft in the FAR, so I went and looked it up (FAR 91.113) and, sure enough, there is no mention of skydivers in the several categories of aircraft and which has right of way in the air.
I also went and read, for the first time, a portion of FAR Part 105.23 c, which covers parachute operations over airports. Sure enough (as I always assumed), the FAR specifically prohibits skydiving ops that would interfere with aircraft in the airport traffic pattern:
“(c) A parachutist may drift over that airport with a fully deployed and properly functioning parachute if the parachutist is at least 2,000 feet above that airport’s traffic pattern, and avoids creating a hazard to air traffic or to persons and property on the ground.”
ALSO
I hear “jumpers away” often, but seldom hear an “Jumpers on ground” call over the CTAF. Seems this would improve communications between jumpers and aircraft in the area.
Well then.....I stand corrected! I assumed, incorrectly a non powered parachutist would have right of way. Never stop learning.
