Mark Y. wrote:Ensure your elevator stops are adjusted correctly before committing to that configuration. Doesn't the audio panel tray have the plugs and wiring coming in from the rear? Would be a nasty mess if the column was pulled back hard and ailerons turned.
I am currently modifying my 182B to a sorta center stack configuration. i am keeping the trays all on top of the column, albeit close, within 1/2". When i was pulling trays I found the chain from the T-Column was actually rubbing on one of the trays from the years of sagging.
https://backcountrypilot.org/images/ori ... 00165b.jpg
Mark Y. wrote:
What is the black firewall sealant you used? I have something the same on my firewall and i need some more. No luck on any searches as to what the part number actually is. I have a split skin on my cabin roof i need to seal from an old repair that wasn't completed properly. Was told to just use RTV, that it won't corrode in my lifetime, but would like to actually find the correct stuff.
colopilot wrote:The new SPW mount is on! Jim came by yesterday to say hi and I immediately put him to work crawling in the cockpit to thread on nuts. He'll learn not to do that sooner or later.![]()
Unfortunately I forgot some washers so we had to take it off and re-do it today, but my A&P and I took care of it since Jim was smart enough to stay home this time. It's fully installed now and torqued, ready to accept LORD mounts and an engine. This mount has significantly more structure than the Cessna mount as I mentioned before, and is braced far better when mounted. It also uses hard mounts to the firewall instead of loosely-torqued rubber bushings.
There is very little tolerance for out-of-true condition on any of this, and they even give solid bushings you can drill yourself if things have shifted over time. Fortunately everything aligned straight and the holes were perfect on the first try. I am really looking forward to getting the 520 hung on this mount soon!
Can't believe you forgot the washers Jim! Haha.jaudette wrote:colopilot wrote:The new SPW mount is on! Jim came by yesterday to say hi and I immediately put him to work crawling in the cockpit to thread on nuts. He'll learn not to do that sooner or later. [emoji38]
Ha ha... Jim: Hey dude whats up.... Ralph: Here take these and get your ass under the panel...
A1Skinner wrote:Ya they are a great mount. Acorn is about 4 hrs drive from me and they do great work. You sure pay for it though...
colopilot wrote:The new SPW mount is on! ...It also uses hard mounts to the firewall instead of loosely-torqued rubber bushings....
