Helio295 wrote:Haha. In April of 2015 I received the response that an FAA STC for the 170 was close and 12 months or less was the estimated completion time. I know these things can and do take time, but I stopped holding my breath 5 years ago.
Verticaltransit wrote:Seems like wingX would still be a worthwhile mod even without the GW increase.
140eagles wrote:When I bought my 170 it came with a set of Bruce’s covers for engine and canopy.
Since the bird lives in its own hangar in Massachusetts I don’t see any reason to put them on (as dust covers e.g.).
The only time I might use them would be during my beloved cross country adventures.
Those don’t happen in frosty temperatures or unexpected snow (let’s forget for a moment my dream about flying in Alaska…) so I’m not sure I need them at all.
Twice I pulled them out of the extended baggage and put them on, just to see how they fit.
What would they protect against? Blowing sand or dust, perhaps? Or envious looks at the instrument panel?
mtv wrote:Verticaltransit wrote:Seems like wingX would still be a worthwhile mod even without the GW increase.
Becomes a very tight fit in a T-Hangar, but performance on floats would benefit for sure. But, the 170 with a bigger engine would really benefit from an increase in gross weight.
mtv wrote:My 170 came with a similar device to capture the rudder. The elevator was locked with the standard Cessna gust lock, which consists of a long piece of bent steel, the end of which goes through a hole in the panel gusset which the control column goes through. Once you line up the control column so that the holes match, you insert the control lock. If it's a Cessna original, it'll then block the throttle with a "RBF" flag on the opposite end.
It's pretty easy to fabricate something like that if you don't have what came with the plane. They are for sale around as well.
This is also what I use on the 175. It locks both the elevators and the ailerons. The rudder lock you show works pretty well on the rudder, or if you don't have something similar, move the tailwheel around till it engages with the rudder. That'll keep the rudder from banging in MOST winds.
Some folks don't like the internal control locks, arguing that the wind then puts stresses on the control cables and circuit. That's true, but first, you SHOULD be parked facing into the wind, in which case, the control lock holds the controls neutral, so no harm no foul. If the winds from behind (sometimes shit happens), then yes, this lock does put some stresses on the control circuits.
I've operated Cessnas for a long time, and worked them in some pretty windy country, and never had any concerns about using the internal control lock.
Just remember to remove prior to flight.....![]()
JamieG wrote:mtv wrote:My 170 came with a similar device to capture the rudder. The elevator was locked with the standard Cessna gust lock, which consists of a long piece of bent steel, the end of which goes through a hole in the panel gusset which the control column goes through. Once you line up the control column so that the holes match, you insert the control lock. If it's a Cessna original, it'll then block the throttle with a "RBF" flag on the opposite end.
I
I have had bent aileron pushrods and a damaged rudder parked tail into wind in a storm using the internal control lock (which has no rudder lock). C180. Couldn’t fly it out. External gust-locks for me now.
140eagles wrote:Let the fun begin…
Actually, it began already some time ago.
Just when the O300 was about to be taken off and sent out for an OH chance teased me with an unexpected alternative: upgrade to an O360!
It took a few days to persuade myself to spend all my money on a childhood dream, but in the end I went for it.
No more O300, just a bunch of old “connections”.
mtv wrote:My 170 never had a baggage door. It was suggested a couple times, but never a high priority. That plane did have an extended baggage.
My 175 has ext. baggage, and no baggage door as well.
Mostly, what I use the ext. baggage for is survival gear….out of sight, out of mind, but always there. So I rarely need to access stuff there.
Finally, I’ve spent thousands of hours working 185s which were equipped with baggage doors. I can’t think of a time those doors were really particularly useful. Handy, maybe, but……
I’m not the least interested in spending the $$ it would take to install a baggage door.
