Backcountry Pilot • narco AT165
narco AT165
7 postsPage 1 of 1
narco AT165
looking to buy narco AT165 transponder to replace AT50A. or any that will plug and play without modification. any of you electechs out there with info on these please respond with info about any units that will go into the same tray without rewiring. thanks R L Messenger
messenger offline
Re: narco AT165
You may find eBay as your best source for used avionics.
Re: narco AT165
Whatever you do, don't pay very much for ANY Narco radios.....
Re: narco AT165
ebay had no at165 listed at all the last few days, and I am aware that narco went bust, but trying to prolong the agony begore I pay to rewire fora different unit. once again, are there any other units besides narco that will plug and play. thanks
messenger offline
Re: narco AT165
Good luck on finding an AT165. I have been looking for one for over 7 weeks. Mine died and they are unrepairable. I have called several used avionics suppliers and still no luck. The last one that came available on e-bay lasted only minutes and it was almost the cost of a Garmin.
S-12Flyer offline
Re: narco AT165
messenger wrote:looking to buy narco AT165 transponder to replace AT50A. or any that will plug and play without modification. any of you electechs out there with info on these please respond with info about any units that will go into the same tray without rewiring. thanks R L Messenger
Garmin sells an adapter tray for their GTX-320A transponder to fit older King and Narco installations. This makes it "slide-in" compatible with your existing Narco AT50A. GTX-320A's can be found for around $1000 and will last.
I'd buy another worthless AT50A for cheap before I spent any real money on an AT165.
Re: narco AT165
thanks for your responses, especially on the garmin tray adapter. RLM
messenger offline
7 postsPage 1 of 1
Users browsing this forum: Google [Bot] and 16 guests
