Backcountry Pilot • New 8.50s installed!
31 postsPage 1 of 21, 2
Sold my Goodyear 8.50s to a friend with a 206 and installed the Desser smooth 8.50s. I got about a half dozen turf and asphalt landings on them today and I’m extremely happy with them. Much softer, much bouncier, quieter than the good years, about 6 lbs ea. lighter, and way cheaper! This is a winning combination for my 172.
Reason: Fixed photo rotation
Jeredp offline
Aircraft: Cessna 172
Loved them tires on my old 172
88Echo offline
Aircraft: 1959 Cessna 172
Re: New 8.50s installed!
Thanks for the info. Looks like an interesting 182 that is your hangar mate. Does it have a Sportsman leading edge?
180Marty wrote:Thanks for the info. Looks like an interesting 182 that is your hangar mate. Does it have a Sportsman leading edge?
His 182 does have the Sportsman kit and several other mods. Nice airplane
Jeredp offline
Looks great Jered!
How do they wear vs the standard 850’s on asphalt?
UT180 offline
UT180 wrote:How do they wear vs the standard 850’s on asphalt?
Mine are holding up pretty good so far after 100+ hours.
I understand the alleged benefit of smoothies, that they don't kick gravel up as readily as tires with tread. But is there a downside, such as lower speed hydroplaning on wet surfaces? Or quicker wear on asphalt? Just guessing. Can someone educate me?
Mine looked brand new after 200+ landings but then I sold the plane. Hydroplaned pretty well. But handled the gravel much better that the tires they replaced. And so light!!!
88Echo offline
I'll probably be replacing my 850 Desser recaps after the summer's flying.
Been leaning toward Airtracs but the Desser smoothies are a possibility.
I'm thinking the 4 ply would be cushier with the same tire pressure.
I'm sure they're plenty stout enough, although technically not since my 850 STC says 6 ply.
They're a few more bucks than the Airtracs, I'm assuming lighter also.
STA's website says 850-6 Airtracs are 16# each,
but Desser doesn't have any specs for this tire available on their website that I could find.
About seven pounds each plus tubes
88Echo offline
How many landings?
rw2 offline
Aircraft: Experimental Maule
How many landings?
I guess I’ll have to go look in my log book and I’ll post later. I’ve been happy with the tires though.
I've been running them for a year and a half. I weighed mine up before I mounted them and I want to say the tire/tube came up to 10.5 lbs. My landings are about 50/50 hard surface-grass, and it might be my imagination, but I think that ground handling on hard surface does more damage to the tires than actual hard surface landings. 780# Tcraft.
nefj40 offline
Aircraft: 2016 cessna cub
88Echo wrote:About seven pounds each plus tubes
Only 7 pounds? Wow!
Website just says "under 10 pounds".
These do not weigh 7 lbs. I have a set in my hangar now for my buggy. Tire and tube weight 10.5 per tire.
www.avthreads.com
Are you sure about that? Was that on a certified scale?
akgreg offline
Aircraft: Yes
Actual weight or calculated? :D
Got my Desser 8.50s on.
Had Goodyear 8.50s all the way around. Went to a 8.00 up front.
gptc offline
Great looking airplane, GPTC!
Is that a Horton or Sportsman leading edge?
Airglas fork? I don't think you can get an 8.00 inside a Cessna HD fork.
Live2aviate offline
