Backcountry Pilot • New 8.50s installed!
31 postsPage 2 of 21, 2
Re: New 8.50s installed!
Thank you! I am very happy with her.
Sportsman STOL cuff.
Airglass fork which comes off a Piper PA 32. I had 8.50s all the way around, but in that configuration it is difficult to get the strut to compress after a full stall landing. You end up taxiing around like a taildragger.
gptc offline
9 or 9.5 pounds for the 8.50 smooths....(without tube)
Great tires.. had a set on for 1.5-2 years? hundreds of landings.. mostly dirt, grass, etc. but some pavement here and there... not much wear at all
GravityKnight offline
Robert's gear / 29" ABWs
VG's / T3 / 75" ww
Love my 8.50 smoothies!
7.0 on the nose.. Maybe next winter I’ll get the air glass fork and stick an 8.0 up front. I think I’d be a little more comfortable on the gravel with that configuration.
Here’s 31R in her natural habitat:
AK737Pilot offline
Aircraft: Cessna 182L
Looks like a "Back Country Baron" in the background?
Anyone know how the smoothies do on snow/ice? I just bought an airglas fork for my 172 and am considering getting a set.
MBpilot88A offline
Aircraft: Cessna 172
They worked great all winter on my old 172. Had them all the way around.
88Echo offline
Aircraft: 1959 Cessna 172
For those that have them on their 182's, any insight on how much the sidewalls flex? I still have single puck brakes on a standard offset disc, this will get changed come Spring. I had a rub issue with Air Tracs I want to avoid. About 70% of our landings are on dirt so these seem like a great option over the Goodyears.
VTOSS offline
Aircraft: 1956 Cessna 182
DHC-2, DHC-8, E175
BH429/407/206, MD500/530
Where did you get your wheel chocks? :D
Lucky offline
Aircraft: '68 Cessna 182
Lucky wrote:Where did you get your wheel chocks? :D
I made them out of 1/8” aluminum. They’re are super lite and big
Jeredp offline
Nice
Lucky offline
Best chocks I’ve found are from Wal Mart’s Aviation/Automotive aisle. They are huge, plastic and dirt cheap. Work fine on ABW 26.
https://www.walmart.com/ip/Rhino-Gear-H ... gKn4PD_BwE
