Backcountry Pilot • Night Flying Accidents/Bad Experiences
22 postsPage 2 of 21, 2
Re: Night Flying Accidents/Bad Experiences
3.8 hours of night in logbook from when I did my Private. I was very uncomfortable. Then again I had all of about 20 hours TT and I was in a POS 150 with not much lighting and an unfamiliar area. My airplane is restricted to Day VFR only per my operating limitations. I guess I should get and instructor and try it in the FBO's 172SP sometime. I've always wanted to take a flight at twilight over a city on the 4th of July.
AvidFlyer offline
REF: Learning Night flying skills
.......good idea at least is go out every 90 days or so and do some pattern work in the dark...minimum...if it scares the hell out of u, take a co-pilot w/you for sure...
How about making that co-pilot you take a CFI....? At least until you are signed off and comfortable with night T & L and pattern work at a variety of airports. Why? If your not PROFICIENT at what you are doing, you should NOT carry passengers! Locally we had a marginal pilot that managed to get night current then took a friend from work while he practiced. Wooops! Stalled it out (C175) maybe 45-50 ft up and crashed onto the edge of the runway and really messed up his 'friends' feet and legs. I may push the edge of the envelope (a chicken-little) but I don't (much) risk some poor trusting soul that is depending on me.
Comments: This time 'he' had a x-wind, and 'he' was marginal all the way around-is the word from other pilots that had seen his 'normal' T & Ls.
Also I am aware that PPLs don't need a sign off, but if your smart, you'll get the instruction, and once you have the instruction, you might as well get the signature. If you happen to bend some metal, it looks good to the FAA folks and they have the discretion to make it a softer 'landing'.
YMMV
lc
Littlecub offline
