Backcountry Pilot • Oil Access
Oil Access
5 postsPage 1 of 1
Oil Access
Has anyone fabricated an oil access Into a 170 cowl, I’m getting tired of opening the complete side and dropping the safety pin into the lake !!
Mapleflt
Mapleflt online
Re: Oil Access
I've never seen an access door added to the "older" style 170 cowling but I did instal the Dip Davis cowling latches on my 170 which makes opening and closing the cowl halves much better. I used the wing style instead of the ones that require a screw driver. Probably better for float operations too.
Here is the link: www.cowllatchstc.com
SkyLarkin offline
Re: Oil Access
SkyLarkin wrote:I've never seen an access door added to the "older" style 170 cowling but I did instal the Dip Davis cowling latches on my 170 which makes opening and closing the cowl halves much better. I used the wing style instead of the ones that require a screw driver. Probably better for float operations too.
Here is the link: http://www.cowllatchstc.com
What he said ^^^^
They work great, on floats for a lot of hours. Mine had the slotted heads, but no big deal. Very positive latches.
Re: Oil Access
Much better, prevents a swim and still provides complete access to the area. So next idea; a cowl support instead of just "flopping" the cowl half across the other, anyone other tackled that demon !!!
Mapleflt
Mapleflt online
Re: Oil Access
Again, I have never seen it done on a 170 but the super cub has a very similar cowling and it uses a small tube attached to the firewall to swing up and prop the cowling open. I think that is something that would be very cheap and easy to make and require a logbook entry only.
SkyLarkin offline
5 postsPage 1 of 1
