My first S-7 had a HEAVY (but reliable and cheap) Subaru conversion, it was easy enough to balance out with lead in the tail plus other junk carried far back. Even then I was (unless loaded for xc) always at the front end of the CG range. My current S-7S with the stretched tail and the much lighter Rotax, flies so much better there is no comparison. I NEVER dead sticked ridge soared my first S-7, now I can and do. These Cub discussions about how the C-90's fly the best, remind me of my experience with the 7.
I just spent the last couple months, and I'm not done yet, spending a few thous to lose a few lbs, like the MGL V6 radio that weighs about 9 ozs. including the built in intercom, while I already had a perfectly serviceable VAL 760 radio and separate intercom.......I saved 4 lbs right there! For only a grand! The lighter battery, moving it forward so no bat box required as it now sits on the floorboards, about 8' less heavy battery cable, a mechanical master mounted on the firewall right by the battery saved another couple lbs. All my steam gauge engine instrument are history, along with all their wiring, and nuts and screws to install them, it really adds up. A GRT EIS 2000 took their place, all I need, another 2 or 3 lbs. I will next pull the 3" AS, ROC, and altimeter, as soon as I get my GRT Mini. If I lose power, I'll fly it by feel. Anoter 2 or 4 lbs gone. The Swiss muffler, 7 lbs. a bit noisier but still damn quiet, and it didn't cost me any $ to drop that weight
Coming from a 180, a few lbs ain't much, but with a 700 and some lb. plane it's huge.
Needing more power for high altitude, maybe, I sure don't, and I sure as heck appreciate the lesser weight when on short final in a off airport situation. You guys needing to keep the freezer filled with moose or caribou, a different story, for going out and having fun and exploring new sites, less is more. Pops has it figured out
