I have an EI carb temp gauge, and use partial carb heat in cruise if conditions are right for icing.
Recently a couple of pilots have told me to only use full heat or none at all.
What do you guys think?
Terry wrote:I have an EI carb temp gauge, and use partial carb heat in cruise if conditions are right for icing.
akflyer2001 wrote:Noe Flight Risk nailed it. Use all carb heat or nothing. Using a little can still cause icing
lesuther wrote:BTW- a lot of the temp drop through the venturi is due to the fuel vaporization- not just the ideal gas law. If you have a gauge, try going to full rich at a constant throttle/rpm setting. You'll see the temp take a noticeable dive if you are over 10k' or so.
182 STOL driver wrote:My 182 has iced up so bad I had a "precautionary" landing year or so back. Had departed in mid December from Southern Calif -climbed above wispy clouds.Carb heat would have helped if I would have added it early .O-470 has terrible air distribution system using carb heat even partial will richen up mixture and smooth out engine in cruise.Now I add carb heat anytime from Oct. -May or when OAT is less than 40 f.
