Some thoughts from inside the rabbit hole looking out……
First a little background on me. I had the same dream as Dave, though a lot less clearly. Some years ago I just had to scratch that itch of owner/operator single pilot. This was back when the FAA was on standstill for handing out certificates and the process took several years to get. I already had a ratty ‘59 180B so that’s the plane I used to get the certificate. I had no clear market or idea of how to get one, and no operating base.
In the interim I worked as a line pilot for several operators around the state. Loved the work but that single-pilot itch just wouldn’t go away. When I finally received my certificate I put it to work any way I could. While I continued to work for others part time, I would take jobs anywhere in Alaska. I made decent money doing it, but lost almost as much. Not wanting to step on the toes of others, particularly the fine operations I had worked for, I primarily took jobs no one else wanted. This mostly meant low-profit or high-risk jobs, often both simultaneously. Fun and rewarding for a time, but not particularly smart business….
I was highly aware that my livelihood was always one small step away from disaster. I learned that good preventative maintenance was not a luxury but a business necessity. Only twice did I have mechanical breakdowns that kept me on the ground for more than a day, but both cost me big jobs. That really hurts when your broke……
Having only one plane is a mixed blessing. One old time single pilot operator who has flown the same Grumman Widgeon for close to half a century told me ‘your second plane is your first mistake.’ There is a lot of truth in that. One aircraft allows you to focus on operating and maintaining that aircraft properly. It has worked well for a number of good single-pilot operations over the years. On the other hand, if something goes wrong with that plane, you’re out of business. I took the other option, and as soon as I could figure out how to borrow money, lined up another ratty Skywagon to have redundant systems. However that deal fell through when I realized how taxing maintaining two beater Cessnas would be. Then a ratty supercub came my way with a deal I couldn’t refuse. More niche market…..
I learned that having a base of operations and a steady market was necessary if one wanted to be successful in the business. Took me a while to learn this one, sure was more fun bouncing here and there wherever I found work. But being focused at one base on a certain market led to more business. All of a sudden I was busier than I could do by myself and hired a pilot and another plane. Of course it was feast or famine. Only a few months of the year was it necessary to have the extra help. Now more business was necessary. Eventually this cycle led to business partners, a merger with the regional mail carrier, more pilots and aircraft etc…..
To Dave’s original questions:
1. Is it silly to not consider a 185? I'm thinking about startup/operating cost, it seems that a 180 can do most of what a 185 can, for a lot less cash.
A 185 is a better commercial plane without a doubt. It has more power, more seats (than an early 180) and can haul a lot more legally. Remember, even though the max gross weight undoubtedly is exceeded on early 180s in Alaska on a regular basis, once you get into the 135 world that is a losing game. Loads should be weighed and W&B limitations respected. To do otherwise will come back to bite you eventually. The 185 has some better mods for a working plane (Cessna cargo pod, Sorenson fuel pod, Flint extended tip tanks, bigger wheel skis, etc.…) Also, the fuel injected Continentals run a lot better in the cold, and in Nome I think you’ll be doing a bit of that!
On the other hand, 185s cost approximately twice what early 180s cost. If you are going to spend the $$, a 206 will be a better option, as others have already noted. On wheels or floats the big trike is Cessna’s most versatile single-pilot plane for a small Alaskan operator. It will out-work and out-earn a 185 two-to-one for most markets! The only thing a 185 will do better is ramp appeal and wheel-ski work. But unless you plan on doing glacier flights, go for the 206.
So why didn’t I take my own advice? For one I didn’t know any better. Also, I legitimately couldn’t afford a 206 or 185. I knew nothing about borrowing money, had no credit history, and was broke! And the 180 did and continues to work. I built a market around it doing economical transport to off-airport locations that were marginal for a Cessna but not time or cost effective in a cub. Not the best business model as it was quite high risk, but it was fun and got me going!
2. I have heard & read: go for an early 180, they can be had for a relative song, are lightweight, great performers. What IS an "early model" 180? We talking 52 to mid 60's? Only 50's?
Quite a few different opinions here. The earlier 180s certainly feel lighter on the controls. When this switch came about was concurrent with the three window fuselage in my experience, but that’s somewhat subjective. I imagine they did gain weight each production year like most aircraft do. As has been pointed out elsewhere by others, most of the weight gain is due to desirable mods. I imagine just a float kit, a thick windshield, large motor and a stol kit would put even the lightest 180 pretty close to a stock early 185. Not to mention extra radios, nicer seats, reinforced cowling after the old one cracks out, etc…. Most early 180s end up getting modified to be more like later ones, this goes triple for working planes! Passengers need reliability, comfort, safety, and hauling space; not a nice light flying ‘feel’ for the pilot. I admit I am partial to the ‘63 and earlier models myself, but simply as a pilot and airplane lover, not as a business owner. In retrospect, I think my friend AK-HUNT had the right idea with taking a late model 185 and stripping out all of the fat, as opposed to taking an early plane and beefing it up to handle the work of later one. Cessna may have known a thing or two about designing aircraft…..
3. Right off the bat items that seem wise: big tires, lightweight battery on firewall, wing extensions, extended baggage.
Big tires – yes if you are working off-airport. Go as big as you can. Bushwheels have made life so much better for those of us that need them. The big soft tires wear out quick, but they sure take the stress off of the airframe if you are landing in the rough.
Light battery – yes. Back to that legal useful load thing….
Wing extensions – yes yes yes. For an early 180 this is the only way to get a gross weight increase and for a working plane that makes ALL the difference. Wing-x levels the playing field a bit for those of us with two window planes.
Extended baggage – yes. Not as critical as the others, especially if you don’t get the up-gross. Even better is a cargo pod. At the moment the Firman pod is not available to the best of my knowledge. It is the best. The Aerocet one is available, just a bit smaller. I only installed one recently (Firman) and now I’m not sure how I did without it! One of best mods available. Adds A LOT of extra room, keeps the weight forward, and great for all manners of stinky, dirty, dangerous, or otherwise undesirable cargo.
Other good mods are a reliable GPS (I prefer the old Garmin 296 but may try the new 796 soon), skis for your country, and a big tailwheel if you will be off-airport in any soft stuff. Keeps the prop overhauls to a minimum.
4. Tough question: when all's said and done with my commercial, I'll probably have 15 hours in a 182. Just enough to be a stitch comfortable with commercial checkride maneuvers. From my experience with my 152, it'll take a hundred or more hours, in a 180, before I'm comfortable doing any sort of "serious" work in it. How do I get from where I am now, to there? Any suggestions? I'll take any input...business planning, financial, strategic big picture...you name it.
In short – go work for someone else first. Since you won’t have the hours to be eligible to fly 135 for some time, get in the industry by working cargo, front desk, maintenance, dispatch, whatever you can. Don’t look down on these jobs like most line pilots do, because remember, when you become single-pilot, you’ll be doing them all! When you get the required hours, fly for someone, anyone, as many operators as you can. The more you can learn from others, the better you will be able to run your own business.
5. To help get the ball rolling, I figure I'll get started working on a 135 to operate the 152 under. I know there's not much I could do, just sightseeing, basically. But it's something. Any suggestions for that?
I’d skip it. Build hours in the 152 on the cheap. Remember, when you put that plane on the certificate it will need to be up to 135 standards. That means all AD’s, SBs complied with (mags at 250 or 500 hours etc…), all timed components in date, 100 and 50 hour inspections by a mechanic on YOUR drug program ($$$), no car gas, and insurance will go though the roof. I don’t know but would guess you would lose money using a 152 for that. Better to build hours on the cheap. When you get to 500, sell the 152 and use the money for a down payment on your 180. Or swap for a 172, at least with that you could do 2 (maybe 3?) person sightseeing tours. Tourists never want to go alone. Also cut-rate village charters would be economical for locals in such a plane. I know of several 135s using 172s for their lowest fare aircraft.
A few thoughts on weather, location, and market:
I briefly considered moving to Nome at one point early in my single-pilot days. My girlfriend (now wife) and I really loved Nome. I was surprised no one was filling this niche market there. And there are lots of tourists! I’m not sure it would be hugely profitable, but there was one else at the time flying off airport for hunters. (At least that I was aware of.) As C-185 points out, the weather can be pretty lousy. But there are a lot of places in the state that are. You learn wherever you are flying and work with it. I’m sure you would have lots of down days, but you are not trying to keep a schedule! Here in Kodiak we can get a bit of weather too – there are times when Alaska Airlines doesn’t make it in for days, but we work with it.
Finally, if it really is your dream and not a passing fantasy – go for it! Listen to all advice, but don’t let anyone talk you out of it. Maybe you’ll make a living at it, maybe not, but at least you’ll have given it a go. I bet you’ll have fun trying.
