Savannah-Tom wrote:After 15 years, I finally got back to Owahee Airstrip in a plane. Crap! Flat tire.
tom
Took the tire off the wheel and found the reason for the flat: big old thorn went right through the thick portion of the tire tread and nailed the tube. I didn't see it when I examined the outside of the tire because it was worn off flush and quite small in diameter.
I've gotten flats from some kind of low bush in the desert, but never on trucks or motor cycles. I guess my plane tires are in-between in resistance. Anyone else punctured a plane tire on thorns?
I think I'll start carrying a patching kit or a spare tube when I head for the outback after this.
tom
