Backcountry Pilot • Project: Cessna 170B BACK IN THE AIR!!!
540 postsPage 24 of 271 ... 21, 22, 23, 24, 25, 26, 27
Re: Project: Cessna 170B
1345
Jeredp offline
Aircraft: Cessna 172
Looks really great. I am at 1340 with 8.50 X 6.00 so Ill guess that.
1337 with required fuel and oil
bcp2012 offline
Aircraft: 1979 Cessna 180K
I got your back, 1290lbs on the 8's :mrgreen:
$1
oh wait....this isn't the price is right? damn....uhhh
1294.5lbs
piperpainter offline
Aircraft: C-205
Was Backcountry Mooney M20C
Looking awesome, Rob! Great job!
I'm guessing 1305.
1362. Wild guess. It'll be fun no matter what.
1313 :shock:
AKT
I hope Im wrong…. 1385
G44
1311
(believe me, I hope Im wrong) But here is my guess....
1398 on 26 ABW "calculated..." I would have to say was in reality with the sportsman, ABWs, and rear bench around 1480 ish.. You stripped the exterior, but painted the interior and some exterior (Imron is a heavy paint) so that's about a wash... You prob saved 50 lbs on removing interior, hat shelf, headliner and carpet, and another 10 on the FW batt, but added 20 in insulation/glue and AeroDot and about 8 with the Selkirk front kick panels and pockets. Selkirk ext baggage adds 11 back in. factory bench seat looses 35, but FA Jumps w/ Rons upholstery adds back 20. Removing the 26's looses about 75lbs, and the 800s add around 20 back on....
Sooooo.... my guess is a pessimistic 1390 with the 5 gal unusable and 8 qts of oil on the little tires. ( Sure hope you come in lighter)
Regardless, she looks awesome!
With a tug like that on my 170 I am sure I would make the triple 7 UPS guys at my strip jealous. Who cares about the weight. Looks are everything.
Coyote offline
My FWF battery shed me 35lbs on my 180. I'll wager on 1323lbs. Hope for you that its lighter!
1305!
bigrenna wrote:(believe me, I hope Im wrong) But here is my guess....
Just let me clarify a few things, the last time this plane was on scales was right before I bought it when Zane owned it, probably in 2007 or so(I'd have to check the logs). It isn't a 60 year old calculated W&B. When Zane had the airplane weighed it was 1349 with the rear seat and 1319 without. I added sportsman stol, bushwheels, double pucks, and a couple other small items and had a calculated W&B at 1398 which I think was fairly accurate. Also, 26" bushwheels are 26lbs each. 8.00x6 good years are 10.9lbs and the tubes are 2.3lbs. Difference of 25.6lbs swapping the tires out. Then the difference from the BBW to the Scott 3200 is another 3.5. So just switching the bushwheels and BBW out should have put me at 1368.9 before any work was done. So if it's not quite a bit lighter than that I'll be disappointed. Also, I decided not to use the Selkirk kick panels and pockets.
My calculated optimistic guess weight is 1285 [-o<
1290 is my guess
Tom offline
Aircraft: PA-18, C-180
Tom wrote:1290 is my guess
This was my guess too, so if we win, we get to split the beer! :mrgreen:
Woo Beer. With all the AvGas I buy, i can't afford to pay attention
Tom offline
He's flying it now! Image
richw56 offline
Aircraft: Cessna 120 125 Lyc.
Congratulations Rob!!!!!!!
MCH offline
